Cold reset can be performed remotely by accessing the Embedded Web Server (EWS).
note:There is a possibility that the tabs are loced by the Administrator, in such case only the Information tab will be visible. Please contact Administrator to unlock other tabs.
caution:Before performing a cold reset, print a menu map and a configuration page. Use the information on these pages to reset customer-specific settings.All HP Jetdirect settings are also reset. Be sure to print a configuration page before performing a cold reset. Make note of the IP address that is listed on the Jetdirect configuration page. You will need to restore the IP address after performing a cold reset.
