HP EliteBook 2560p Notebook PC - Removing and Replacing the Wireless WAN Minicard
This document is provided to assist in removing and replacing the wireless WAN minicard for the HP EliteBook 2560p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Tools required
  • Smooth jaw, bent-tipped needle nose pliers (optional)
  • Small, smooth-tipped needle nose pliers (optional)
  • Tweezers
  • Small, Phillips-head (P1) screwdriver
Parts required
The replacement part number will vary depending on the wireless WAN minicard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
HP un2430 EV-DO/HSPA mobile broadband module (all countries and regions except the People's Republic of China)
634400-001 (Modified)
Yes
HP hs2340 HSPA+ mobile broadband module
632155-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the wireless WAN minicard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Wireless WAN Minicard from the menu on the upper left hand side of the screen.
Click here to view the wireless WAN minicard removal video (right-click on the link to open in a new window/tab).
Wireless WAN minicard removal
Observe all precautions when removing and replacing components.
  2. Carefully disconnect the wireless antenna cables from the wireless WAN minicard with a small pair of needle nose pliers or tweezers.
    Make careful note of which wireless antenna cable is connected to each terminal on the wireless WAN minicard for later replacement.
    Use care when disconnecting the wireless antenna cables from the wireless WAN minicard. Damaged cables or connectors can degrade notebook performance.
  3. Remove the two 3-mm P1 Phillips-head screws that secure the wireless WAN minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless WAN minicard by the edges and pull gently to remove it.
  5. Place the wireless WAN minicard in a static dissipative bag.
Wireless WAN minicard replacement
  1. Grasp the wireless WAN minicard by the edges and remove it from the static dissipative bag.
  2. Align the notch in the wireless WAN minicard with the key in the wireless WAN minicard slot on the system board.
  3. At an angle, gently insert the wireless WAN minicard into its slot on the system board.
  4. Press the wireless WAN minicard down and replace the two 3-mm P1 Phillips-head screws that secure the wireless WAN minicard to the system board.
  5. Reconnect the wireless antenna cables to the wireless WAN minicard.
    Use care when connecting the wireless antenna cables to the wireless WAN minicard. Damaged cables or connectors can degrade notebook performance.
