HP ProBook 4431s Notebook PC - Removing and Replacing the USB Board
This document is provided to assist in removing and replacing the USB board for the HP ProBook 4431s Notebook PC.
Minimum skill level
The end user should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P1) screwdriver.
Parts required
The replacement part number will vary depending on the USB board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
USB 2.0 board
646360-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the USB board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to Service Media Library), then select USB board from the menu on the upper left hand side of the screen.
Click here to view the USB board removal video (right-click on the link to open in a new window/tab).
USB board removal
Observe all precautions when removing and replacing components.
  2. Gently lift up on the locking bar of the USB board ZIF connector and remove the USB board ribbon cable.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  3. Lift the USB board ribbon cable from the base enclosure.
    The USB board ribbon cable is held in place with double-sided adhesive.
  4. Remove the one 4-mm P1 Phillips-head screw that secures the USB board to the base enclosure.
  5. Lift and remove the USB board and ribbon cable from the base enclosure.
  6. Place the USB board and cable in a static dissipative bag.
USB board replacement
  1. Grasp the USB board by the edges and remove it from the static dissipative bag.
  2. Place the USB board over the screw holes and alignment pins built into the base enclosure.
  3. Replace the one 4-mm P1 Phillips-head screw that secures the USB board to the base enclosure.
  4. Insert the USB board ribbon cable into the ZIF connector on the system board and gently press down on the ZIF connector locking bar.
  5. Press down on the USB board ribbon cable to adhere it to the base enclosure.
Country: Flag Thailand
