HP Printers - Updating or Upgrading Printer Firmware
This document is for HP inkjet and LaserJet printers.
HP regularly releases new printer firmware versions with product enhancements or issue fixes. Depending on your printer, apps on the printer control panel might also receive updates. Update firmware and apps on a regular basis to make sure you are getting the most out of your printer.
Use one of the following methods to upgrade the firmware. If one method does not work, try one of the other methods.
Do NOT turn off the printer until the update is complete. Turning off the printer during an update can damage your printer.
