Replacing the Graphics Card and Expansion Cards for HP Slimline s5-1000 and 400-000 Desktop PCs
This document applies to HP Slimline s5-1000 400-000 and series desktop computers.
HP Slimline s5-1000 series desktop computerHP Slimline 400-000 series desktop computer
Before you begin
  • You need a flathead screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Video overview
Removing and replacing the graphics card
  warning:
Removing the graphics card
Follow the steps in this section to remove a graphics card.
Step 1
Remove the side panel.
For more information about removing the side panel, refer to the HP support document Removing and Replacing the Side Panel.
Pulling off the panel
Step 2
Remove the screw that secures the expansion slot lock to the computer.
Save this screw for graphics card replacement.
Removing the screw
Step 3
Pull the expansion slot lock off the computer.
Removing the expansion slot lock
Step 4
Press down on the latch holding the graphics card to the motherboard, and...
Graphics card latch
...remove the graphics card from the computer.
Replacing the graphics card
Use the steps in this section to replace the graphics card.
Step 1
Align the graphics card into the slot on the motherboard and carefully push it until it is secure.
Aligning the graphics card
Step 2
The expansion slot lock has three tabs...
The three tabs
...that fit into three slots on the rear of the computer.
The three slots
Step 3
Align the hooks of the slot lock into the slots on the computer and swing the slot lock into place.
Swinging the slot lock into place
Step 4
Replace the screw that secures the expansion slot lock to the computer.
Replacing the screw
Step 5
Replace the side panel.
For more information about replacing the side panel, refer to the HP support document Removing and Replacing the Side Panel.
Replacing the panel
Removing and replacing an expansion card
  warning:
Removing an expansion card
Follow the steps in this section to remove an expansion card.
Step 1
Step 2
Save this screw for expansion card replacement.
Removing the screw
Step 3
Step 4
Pull on the edges of the expansion card to release it from the expansion slot and remove it from the computer.
Removing the expansion card
Replacing the expansion card
Use the steps in this section to replace the expansion card.
Step 1
Carefully seat the card in its slot until it is secure.
Step 2
The three tabs
The three slots
Step 3
Step 4
Replacing the screw
Step 5
Replacing the panel
