HP ProBook 4331s Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the keyboard for the HP ProBook 4331s Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdriver
Parts required
The replacement part number will vary depending on the keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboard - For use in HP ProBook 4331s Notebook PC
646365-xx1 (Modified)
Yes
The part number will vary based on the country. Click here for a list of country specific spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
    • Failure to comply with the precautions could result in damage to your product or loss of data.
    • Observe all precautions when removing and replacing components
  2. Slide the battery release latches towards the battery icons to disengage the battery.
  3. Remove the battery by lifting it out of the battery bay.
  4. Slide the battery release latches towards the battery icons until the service door disengages from the base enclosure.
  5. Lift the service door and remove it.
  6. Remove the one 4-mm P1 Phillips-head screw identified with an optical disk drive icon that secures the optical disk drive to the base enclosure.
  7. Release the optical disk drive from the base enclosure by sliding the tab marked with an optical disk drive icon to the left.
  8. Grasp the edge of the optical disk drive bezel and slide the optical disk drive out of the base enclosure.
  9. Remove the optical disk drive.
  10. Remove the one 6-mm P1 Phillips-head screw identified with a keyboard icon that secures the keyboard to the base enclosure.
  11. Remove the one 4-mm P1 Phillips-head screw next to the system fan that secures the keyboard to the base enclosure.
  12. Using a probe tool, gently press into the optical disk drive bay until the keyboard releases from the top cover.
  13. Turn the notebook right side up and open the display panel fully.
  14. Using finger or a flat bladed non-marring tool, gently lift up on the rear edge of the keyboard to disengage the keyboard from the top cover.
  15. Slide the keyboard towards the rear of the notebook to release the tabs at the front of the keyboard.
  16. Turn the keyboard face down on the top cover.
    Do not lift the keyboard further away from the notebook than necessary to access the keyboard ribbon cable and ZIF connector.
  17. Gently lift up on the locking bar to the keyboard ZIF connector and remove the keyboard ribbon cable.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  18. Remove the keyboard.
Keyboard replacement
  1. Place the keyboard face down on the top cover so that the keyboard ribbon cable and ZIF connector are accessible.
  2. Insert the keyboard ribbon cable into the ZIF connector on the system board and gently press down on the ZIF connector locking bar.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat until it engages with the top cover.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the one 4-mm P1 Phillips-head screw next to the system fan that secures the keyboard to the base enclosure.
  7. Replace the one 6-mm P1 Phillips-head screw identified with a keyboard icon that secures the keyboard to the base enclosure.
  8. Slide the optical disk drive into the optical disk drive bay.
  9. Replace the one 4-mm P1 Phillips-head screw identified with an optical disk drive icon that secures the optical disk drive to the base enclosure.
  10. Place the service door on the base enclosure.
  11. Slide the service door towards the rear of the notebook until it clicks into place.
  12. Lower the rear edge of the battery into the battery bay.
  13. Lower the front edge of the battery until it clicks into place.
Country: Flag Thailand
