HP Photosmart 6510 e-All-in-One Printer Series - Setting up the All-in-One (Hardware)
  • Unpack the product
  • Connect the power cord and turn on the power
  • Select the language and location
  • Insert the cartridges
  • Load paper
  • Align the cartridges
Follow these steps in order to set up your printer.
Do NOT connect the USB cable now. If you need a USB cable to connect the product to the computer, you will be prompted to connect it at the correct time during software installation.
Step two: Unpack the All-in-One
  1. Remove all tape and packing material from the product.
    Figure : Remove all packing materials
    Image: Remove all packing materials
  2. Open the cartridge access door, and then remove the tape from inside the product.
    Figure : Open the cartridge access door, and then remove the tape from inside the product
    Image: Open the cartridge access door, and then remove the tape from inside the product
  3. Close the cartridge access door.
  4. Pull out the paper tray, and then remove the tape from the tray.
    Figure : Remove tape from the paper tray
    Image: Remove tape from the paper tray
  5. Push the paper tray back into the product.
Step three: Connect the power cord and turn on the All-in-One
  1. Connect the power cord to the rear of the product, and then plug it into a wall outlet.
    Figure : Connect the power cord
    Image: Connect the power cord
  2. Press the Power button () to turn on the product.
    Figure : Press the Power button
    Image: Press the Power button
Step four: Select your language and country/region
When you turn on the product, it prompts you to select your language and region. Follow these steps to set the default language and country/region for your product.
  1. Touch your desired language, and then touch Yes to confirm the language choice. The Set Region Menu displays.
  2. Touch your desired region, and then touch Yes to confirm the country/region choice.
Step five: Load photo paper
If you do not have photo paper or if you prefer to load photo paper in the future, skip to the next step in this document.
  1. Pull open the photo tray, and then slide the paper width guides to their outermost positions.
    Figure : Slide the paper width guides to their outermost positions
    Image: Slide the paper width guides to their outermost positions
  2. Load a stack of photo paper into the tray, with the short edge facing toward the product and the print side down. Push the stack into the tray until it stops.
    Figure : Load photo paper into the tray
    Image: Load photo paper into the tray
  3. Slide the paper width guides in until they rest against the edges of the paper.
    Figure : Slide the paper width guides until they rest against the edges of the paper
    Image: Slide the paper width guides until they rest against the edges of the paper
  4. Close the photo tray, and then push the paper tray into the product.
    Figure : Close the photo tray, and then push the paper tray into the product
    Image: Close the photo tray,  and then push the paper tray into the product
  1. If the photo tray is open, close the photo tray, and then pull the paper tray toward you until it is open.
  2. Slide the paper width guides to their outermost positions.
    Figure : Slide paper width guides to their outermost positions
    Image: Slide paper width guides to their outermost positions
  3. Load a stack of plain paper into the tray with the short edge facing toward the product and the print side down (if the paper has a print side). Push the stack into the tray until it stops.
    Figure : Load paper into the tray
  4. Slide the paper width guides until they rest against the edges of the paper.
    Figure : Slide the paper width guides against the edges of the paper
    Image: Slide the paper width guides against the edges of the paper
  5. Close the tray, pull the tray extender toward you, and then extend the paper catch until it is fully extended.
    Figure : Close the tray, and then extend the paper extender and the paper catch
    Image: Close the tray, and then extend the paper extender and the paper catch
Step seven: Install the cartridges
  1. Open the cartridge access door. The carriage moves to the access area.
  2. Remove the protective cap from the carriage.
    Figure : Remove the protective cap from the carriage
    Image: Remove the protective cap from the carriage
  3. Pull the orange tab to remove the plastic wrap from a cartridge.
    Figure : Remove the plastic wrap from a cartridge
    Image: Remove the plastic wrap from a cartridge
  4. Remove the orange cap from the cartridge. Twist the cap counter-clockwise until it snaps off.
    Figure : Remove the orange cap from the cartridge
    Image: Remove the orange cap from the cartridge
  5. With the nozzle and the contacts facing down, push the cartridge into its slot. Press down on the cartridge until it clicks into place. Make sure that the color icon on the cartridge label matches the color icon on the slot.
    Figure : Insert the cartridge
    Image: Insert the cartridge
  6. Repeat these steps to insert the other cartridges.
  7. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door
Step eight: Align the cartridges
After you load the cartridges and close the cartridge access door, the product automatically prompts you to print an alignment page.
  1. On the product control panel, touch OK. The alignment page prints.
    If the product does not automatically print an alignment page, follow these steps:
    1. From the home screen, touch the Setup icon (), and then touch Tools.
    2. Touch the Down Arrow (), and then touch Align Printer. The alignment page prints.
Country: Flag Thailand
