    We are upgrading our website
Replacing the Power Supply in HP Pavilion HPE h8-1000 and HP ENVY 700 Desktop Series PCs
This document applies to HP Pavilion HPE h8-1000 series desktop computers.
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Video overview
Removing the power supply
Use the steps in this section to remove the power supply.
  warning:
Step 1
Remove the side panel.
For more information about removing the side panel, refer to the HP support document Removing and Replacing the Side Panel.
Pulling off the panel
Step 2
Detach all power connectors to the motherboard,...
Motherboard power connectors
all optical drives,...
Optical drive power connectors
...and hard drives.
Hard drive power connectors
Step 3
Remove the four screws that connect the power supply to the computer.
Save the screws for power supply replacement.
Removing the four screws
Step 4
Press the latch at the bottom of the power supply, and...
Power supply latch
...pull the power supply into and out of the computer.
Replacing the power supply
Use the steps in this section to replace the power supply.
  warning:
Always replace the entire power supply. Never attempt to disassemble the power supply or work on components within the power supply unit.
Step 1
Find the latch, guide, and ledge inside the computer that help secure the power supply.
    Inside of computer
  1. Latch
  2. Guide
  3. Ledge
Step 2
Align the power supply with the ledge and guide, and...
Aligning the power supply
...slide it back until it snaps into place.
Sliding the power supply
Step 3
Replace the four screws that connect the power supply to the computer.
Replacing the four screws
Step 4
Reconnect all power connectors to the motherboard, optical drives, and hard drives.
Step 5
Replace the side panel.
For more information about replacing the side panel, refer to the HP support document Removing and Replacing the Side Panel.
Replacing the panel
Country: Flag Thailand
