HP Compaq 6200 Pro Microtower PC - Removing and Replacing the Power Supply
This document applies to the HP Compaq 6200 Pro Microtower PC.
Before you begin
  • A Torx-15 screwdriver is required for this procedure.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the power supply, right-click the removing the power supply video and select Open link in new window/tab. Additional product videos can be found on the HP Service Media Library.
Replacement part information
Part Number
Requires Return
Power supply unit (320 W), EPA 90% efficiency, 12 V dc output
613764-001 (Modified)
Yes
Power supply unit (320 W), standard 12 V dc, four outputs
613765-001 (Modified)
Yes
Part numbers are subject to change. See the HP PartSurfer Website for current part numbers.
If the part requires return, click on the appropriate link below:
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Removing the power supply
Perform the following to remove the power supply:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Remove the side panel.
Step 2
Remove the front fan assembly.
Remove the front fan.
Step 3
Disconnect the power cables from the system board, noting their location for reinstallation.
Disconnect the cables.
Step 4
Remove the four Torx-15 screws that secure the power supply to the back of the chassis.
Remove the screws.
Step 5
Press the release latch on the chassis pan and slide the power supply away from the back of the computer.
Release the latch.
Step 6
Lift the power supply out of the computer.
Remove the power supply.
Replacing the power supply
Perform the following to replace the power supply:
Step 1
Align the power supply with the guides on the computer.
Align the power supply.
Step 2
Slide the power supply to the back of the computer.
Replace the power supply.
Step 3
Replace the four Torx-15 screws that secure the power supply to the back of the computer.
Replace the screws.
Step 4
Connect the power cables to the system board.
Replace the cables.
Step 5
Replace the front fan assembly.
Replace the front fan.
Step 6
Replace the side panel.
Country: Flag Thailand
