HP Compaq 6200 Pro Microtower PC - Removing and Replacing the Memory
This document applies to the HP Compaq 6200 Pro Microtower PC.
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the memory, right-click the removing the memory video and select Open link in new window/tab. Additional product videos can be found on the HP Service Media Library.
Replacement part information
Part Number
Requires Return
4GB, PC3-10600, DDR3-1333 MHz, 240-pins, non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
585157-001 (Modified)
Yes
2GB, PC3-10600, DDR3-1333 MHz, 240-pins, non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
635803-001 (Modified)
Yes
1GB, PC3-10600, DDR3-1333MHz, 240-pins, non-ECC, unbuffered DIMM (Dual In-Line Memory Module)
635802-001 (Modified)
Yes
Part numbers are subject to change. See the HP PartSurfer Website for current part numbers.
If the part requires return, click on the appropriate link below:
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Removing the memory
Perform the following to remove the memory:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Remove the side panel.
Step 2
Remove any cables blocking access to the memory.
Remove the cables.
Step 3
Push down and out on the memory socket latches to release the memory module.
Release memory module.
Step 4
Pull the memory module up and out of the socket.
Remove the memory module.
Replacing the memory
Perform the following to replace the memory:
Step 1
Ensure that the memory socket latches are pushed down and away from the memory socket.
Lower the memory socket latches.
Step 2
Match the notch on the memory module with the key in the memory socket.
Close up image of the memory module notch in the module and key in the socket.
Step 3
Push the module down firmly into the socket until the latches snap into place and the module is fully seated.
Pressing the memory module into the socket.
Step 4
Replace the side panel.
Country: Flag Thailand
