HP TouchSmart 9300 Elite All-in-One Business PC - Removal and Replacement Procedures
The following sections provide information about disassembling various components of the All-in-One.
Preparing to disassemble the computer
To avoid injury and equipment damage, always complete the following steps in order, when opening the All-in-One.
  1. Remove all removable media, such as compact discs or USB flash drives, from the computer.
  2. Turn off the computer properly through the operating system, then turn off any external devices.
  3. Disconnect the power cord from the power outlet and disconnect any external devices.
    Regardless of the power-on state, voltage is always present on the system board as long as the system is plugged into an active AC outlet. You must disconnect the power cord to avoid damage to the internal components of the computer.
  4. Disconnect all cables from the ports.
  5. Place the computer face down on a soft flat surface. HP recommends that you set down a blanket, towel, or other soft cloth to protect the screen surface from scratches or other damage.
Static electricity can damage the electronic components of the computer. Before beginning these procedures, ensure that you are discharged of static electricity by briefly touching a grounded metal object.
  warning:
Beware of sharp edges inside the chassis.
Stand
The stand is secured with four screws. The screws are covered by the plastic piece covering the back of the stand.
To remove the stand:
  1. Prepare the computer for disassembly (see Preparing to disassemble the computer).
  2. Insert your finger, or a flathead screwdriver, into the slot on the stand cover (1) to pry it off of the computer stand.
    Figure :
  3. Remove the four Torx screws (1), slide the stand toward the top of the computer, and then lift the stand off the computer (2).
    You can use a Torx or a flat-head driver to remove the screws.
    Figure :
To replace the stand, reverse the removal procedures.
Weight (with integrated graphics) without stand: 8.75 kg (19.3 lbs)
Weight (with discrete graphics) without stand: 9.05 kg (20.0 lbs)
VESA mount
The VESA adapter plate is stored in the bottom of the stand and is mounted in place of the stand.
To install the VESA adapter plate:
    Figure :
  3. Use a Phillips screwdriver to tighten the recessed two brake screws (for the rails) on the computer. It should take about 5–10 turns of the screwdriver to secure the screws. Take care not to overtighten the screws.
    The tightened brake screws will hold the VESA adapter plate in the locked position, so that the computer does not slide down once it is mounted on a wall. These screws must be tighten before placing the VESA adapter plate on the back of the computer.
    Figure :
  4. While the stand is still on the computer, use a Phillips screwdriver to remove the four screws attaching the VESA adapter plate to the bottom of the computer stand. Save the screws.
    Figure :
  5. Remove the VESA adapter plate from the bottom of the computer stand.
    Figure :
  6. Use a flathead screwdriver to remove the four screws attaching the computer stand to the back of the computer.
    Figure :
  7. Lift the computer stand away from the computer.
    Figure :
  8. Place the VESA adapter plate over the rails on the back of the computer, matching the cutouts on the each side of the plate with the screw holes and the hooks on the rails.
    Figure :
  9. Attach the VESA adapter plate to the back of the computer, using a Phillips screwdriver to tighten the four screws.
    Figure :
  10. Slide the VESA adapter plate upward until it locks into place. You will hear a click when the VESA adapter plate is locked in place.
    If you do not hear the click or the plate does not lock in place, it means the two brake screws were not sufficiently tightened when the computer stand was removed. Unscrew the four screws on the VESA adapter plate and remove it, then retighten the two brake screws (see step 4 in previous section). Replace the VESA adapter plate by installing and tightening the four screws, then slide the plate up until it locks in place.
    Figure :
  11. Attach the wall-mounting hardware (purchased separately) to the VESA adapter plate, according to the manufacturer's instructions, using either the 100 mm x 100 mm screw holes or the 100 mm x 200 mm screw holes.
    Figure :
    Figure :
    The computer can be mounted in either landscape or portrait orientation. If mounted in portrait orientation make sure the CD/DVD drive is at the top. For landscape orientation, keep the same orientation as when the computer is on the stand.
If the computer stand is ever replaced on the computer, the VESA adapter plate must be replaced on the bottom of the computer stand in order to properly support the computer.
Note the following information about the computer without the stand but with the VESA adapter installed.
The measurements in the illustration are in mm.
Computer dimensions without stand
Figure :
Rear panels
The rear panels are located above the stand. You must remove them to access internal components. Although the following procedure shows only removing one panel, the procedure is the same for both panels.
To remove the rear panels:
  2. Remove the small center panel below the rear ports by pulling out the top of the panel (1) then lifting the panel off the computer (2).
    Figure :
  3. Before removing the rear panel, you must remove the small cover plate that hides the screw used to secure the panel to the chassis. Lift up on the bottom of the cover plate located next to the upper inside corner of the rear panel and lift the cover plate off the rear of the computer.
    Figure :
  4. Remove the screw beneath the cover plate (1) and slide the rear panel toward the center of the computer until it stops (approximately 5 mm or 1/5 inch) (2). Use the raised grip areas on the top and bottom inside corners of the panel to slide it toward the center of the computer.
    Figure :
  5. Lift up the outside edge of the panel approximately 2.5 cm (1 inch) (1) and slide the panel toward the outside edge of the computer (2) to remove it.
    Figure :
To replace the rear panels, reverse the removal procedures.
When replacing a drive access panel, hold the panel at a slight angle with the inside edge of the panel lower than the outside edge, then slide the screw hole tab on the top inside corner of the panel into the slot on the rear of the computer.
Replacing the drive access panel
Figure :
Installing memory
Spare part number
4-GB
646801-001
2-GB
646800-001
The memory modules are located under the rear cover on the right side of the computer (when viewed from behind).
Memory location
Figure :
The computer comes with double data rate 3 synchronous dynamic random access memory (DDR3-SDRAM) small outline dual inline memory modules (SODIMMs).
DDR3-SDRAM SODIMMs
For proper system operation, the SODIMMs must be:
  • industry-standard 204-pin
  • unbuffered non-ECC PC3-10600 DDR3-1333 MHz-compliant
  • 1.5 volt DDR3-SDRAM SODIMMs
The DDR3-SDRAM SODIMMs must also:
  • support CAS latency 9 DDR3 1333 MHz (9-9-9 timing)
  • contain the mandatory Joint Electronic Device Engineering Council (JEDEC) specification
In addition, the computer supports:
  • 512-Mbit, 1-Gbit, and 2-Gbit non-ECC memory technologies
  • single-sided and double-sided SODIMMs
  • SODIMMs constructed with x8 and x16 devices; SODIMMs constructed with x4 SDRAM are not supported
The system will not operate properly if you install unsupported SODIMMs.
Populating SODIMM sockets
The memory sockets on the system board can be populated with up to four industry-standard SODIMMs. These memory sockets are populated with at least one preinstalled SODIMM. To achieve the maximum memory support, you can populate the system board with up to 16 GB of memory.
There are four SODIMM sockets on the system board, with two sockets per channel. The sockets are labeled DIMM1, DIMM2, DIMM3, and DIMM4. Sockets DIMM1 and DIMM2 operate in memory channel A. Sockets DIMM3 and DIMM4 operate in memory channel B.
SODIMM socket locations
Figure :
Item
Socket Color
1
DIMM1 socket, Channel A (populate first)
black
2
DIMM2 socket, Channel A (populate third)
white
3
DIMM3 socket, Channel B (populate second)
black
4
DIMM4 socket, Channel B (populate fourth)
white
A SODIMM must occupy the black DIMM1 socket. Otherwise, the system will display a POST error message indicating that a memory module is installed in the wrong socket
The system will automatically operate in single channel mode, dual channel mode, or flex mode, depending on how the SODIMMs are installed.
  • The system will operate in single channel mode if the SODIMM sockets are populated in one channel only.
  • The system will operate in a higher-performing dual channel mode if the total memory capacity of the SODIMMs in Channel A is equal to the total memory capacity of the SODIMMs in Channel B. The technology and device width can vary between the channels. For example, if Channel A is populated with two 1 GB SODIMMs and Channel B is populated with one 2 GB SODIMM, the system will operate in dual channel mode.
  • The system will operate in flex mode if the total memory capacity of the SODIMMs in Channel A is not equal to the total memory capacity of the SODIMMs in Channel B. In flex mode, the channel populated with the least amount of memory describes the total amount of memory assigned to dual channel and the remainder is assigned to single channel. For optimal speed, the channels should be balanced so that the largest amount of memory is spread between the two channels. If one channel will have more memory than the other, the larger amount should be assigned to Channel A. For example, if you are populating the sockets with one 2 GB SODIMM, and three 1 GB SODIMMs, Channel A should be populated with the 2 GB SODIMM and one 1 GB SODIMM, and Channel B should be populated with the other two 1 GB SODIMMs. With this configuration, 4 GB will run as dual channel and 1 GB will run as single channel.
Installing SODIMMS
When facing the rear of the computer, there are four memory sockets located behind the large access panel on the right. You must remove this panel to remove or install memory.
When handling a memory module, be careful not to touch any of the contacts. Doing so may damage the module.
To remove or install memory modules:
  2. Remove the right rear panel (see Rear panels).
  3. To remove a SODIMM, press outward on the two latches on each side of the SODIMM (1) then pull the SODIMM out of the socket (2).
    Figure :
  4. To install a SODIMM, slide the new SODIMM into the socket at approximately a 30° angle (1) then press the SODIMM down (2) so that the latches lock it in place.
    Figure :
    A memory module can be installed in only one way. Match the notch on the module with the tab on the memory socket.
  5. Reconnect and reconfigure the computer. The computer automatically recognizes the additional memory when you turn on the computer.
Spare part number
1000-GB
636930-001
750-GB
639363-001
500-GB
636939-001
320-GB
634824-001
250-GB
636927-001
160-GB solid-state drive
646809-001
80-GB solid-state drive
607817-001
The hard drive is located under the rear panel on the left side of the computer (when viewed from behind). The drive is secured with one captive screw and is housed in a removable cage.
Hard drive location
Figure :
To replace the hard drive:
  2. Remove the left rear panel (see Rear panels).
  3. Loosen the captive screw on the side of the hard drive cage that secures the cage to the computer.
    Figure :
  4. Grasp the handle on top of the hard drive cage and slide the cage toward the outer edge of the computer, then lift the cage out of the computer.
    Figure :
  5. To remove the hard drive from the hard drive cage, remove the four screws on the sides of the cage that secure the drive to the cage (1), and then slide the drive out of the cage (2).
    Figure :
  6. Reconnect and reconfigure the computer.
To install a hard drive, reverse the removal procedures.
Inverter board
Spare part number
Inverter board
658982-001
The inverter board is located on the left side of the computer on top of the optical drive cage. It is secured with two screws and has two connectors.
Inverter board location
Figure :
To remove the inverter board:
  3. Remove the two screws (1) that secure the board to the computer.
  4. Disconnect the two cables from the board (2).
    Be careful not to damage the cables when disconnecting them from the board. Do not pull on the wires.
  5. Remove the inverter board from the computer (3).
    Figure :
To install the inverter board, reverse the removal procedures.
Optical drive connector board
Spare part number
652311-001
Optical drive transfer cable, 275 mm
652286-001
The optical drive connector board is located on the left side of the computer (when viewed from behind). It is secured by two screws and has two connectors – one to the system board, one to the optical drive eject board.
Optical drive connector board location
Figure :
To remove the optical drive connector board:
  3. Disconnect the two cables (1) from the board.
    Be careful not to damage the cable when disconnecting it from the board. Do not pull on the wires.
  4. Remove two screws (2) that secure the board to the computer.
  5. Pull the board away from the optical drive bracket, and then remove it from the computer (3).
    Figure :
  6. Remove the board from the computer.
To install the optical drive connector board, reverse the removal procedures.
Left cap
Spare part number
Left side cap, no optical drive
658989-001
The left cap is located on the left side of the computer. You must remove it to remove the optical drive, optical drive eject board, rear logo cover, and main rear frame.
Left cap location
Figure :
To remove the left cap:
  3. Move the two screws (1) that secure the cap to the computer.
  4. Rotate the cap to disengage it from the computer (2), and then remove it (3).
    Figure :
To install an left cap, reverse the removal procedures.
Optical drive
Spare part number
HP SuperMulti DVD Writer Drive
583092-001
HP Slim Slot Blu-ray Combo Drive
583093-001
The optical drive is located under the drive cover on the left side of the computer (when viewed from behind). It is secured with one screw. You must remove the left side cap to remove the optical drive.
Optical drive location
Figure :
To remove the optical drive:
  3. Remove the left cap (see Left cap).
  4. Loosen the captive screw (1) that secures the drive to the computer, and then push on the drive bracket (2) to slide the drive out of the computer (3).
    Figure :
  5. If you need to remove the drive bracket from the drive, remove the two screws (1) that secure the bracket to the drive, and then remove the bracket from the drive (2).
    Figure :
To install an optical drive, reverse the removal procedures.
Optical drive eject board
Spare part number
652312-001
Optical drive eject cable, 190 mm
652299-001
The optical drive eject board is located under the left side cap. It is secured with one screw and has one connector.
Optical drive eject board location
Figure :
To remove the optical drive eject board:
  3. Remove the left side cap (see Optical drive).
  4. From the outside of the computer, remove the screw that secures the board to the computer.
    Figure :
  5. From the inside of the computer, disconnect the cable from the board.
    Be careful not to damage the cable when disconnecting it from the connector. Do not pull on the wires.
    Figure :
To install the optical drive eject board, reverse the removal procedures.
Right cap
The right cap is located along the right side of the computer (when viewed from behind). It is secured with two screws, and it houses the volume board. You do not have to remove the volume board when removing the cap if you disconnect the volume board cable from the system board.
Right cap location
Figure :
To remove the right cap:
  3. Move the two screws (1) that secure the right side cap to the computer.
  4. Rotate the cap to disengage it from the computer (2), and then remove it far enough to gain access to the volume board cable connector (3).
    Figure :
  5. Disconnect the volume board cable from the system board.
    Figure :
  6. Remove the cap from the computer.
To install the right cap, reverse the removal procedures.
Volume button board
Spare part number
Volume button board
652306-001
The volume button board is located in the right side cap. It is secured with two screws and has one connector.
Volume button board location
Figure :
To remove the volume board:
  3. Remove the right cap (see Right cap).
  4. Remove the two screws (1) that secure the board to the right cap.
  5. Lift the board from the cap (2).
    Figure :
To install the volume button board, reverse the removal procedures.
Webcam module
Spare part number
Webcam module without DMIC
652277-001
Webcam module, 2.0 MP, FHD
658985-001
Webcam lens cover
654598-001
Webcam wheel cap
658986-001
The webcam module is located at the top of the computer. It is secured with two screws and has one connector.
Webcam module location
Figure :
To remove the webcam module:
  2. Remove the left and right rear panels (see Rear panels).
  3. Remove the rear logo cover (see Rear logo cover).
  4. Remove the two screws (1) that secure the webcam module to the computer.
  5. Disconnect the cable from the system board (2).
  6. Remove the module from the computer (3).
    Figure :
To install a webcam module, reverse the removal procedures.
Main rear frame
The main rear frame is secured with 15 screws. To remove it, you must first remove the rear logo cover, which is held on with four screws.
To remove the main rear frame:
  2. Remove the stand (see Stand).
  3. Remove the left and right rear panels (see Rear panels).
  4. Remove the left cap (see Left cap).
  5. Remove the right cap (see Right cap).
  6. Remove the rear logo cover (see Rear logo cover).
  7. Remove the 15 screws that secure the frame to the computer, as follows:
    • Top: 6 screws
    • Bottom: 4 screws
    • Left: 3 screws
    • Right: 2 screws
    Be sure to mark the locations of the rear frame screws as you remove them. If you also remove the display panel, it is difficult to determine which screws are used for which component if you do not have them marked.
    Figure :
  8. Lift the frame from the computer.
To replace the main rear frame, reverse the removal procedures.
Power button board
Spare part number
Power button board
652305-001
The power button board is located under the left side cap near the bottom of the computer. It is secured with one screw and has one connector.
Power button board location
Figure :
To remove the power button board:
  3. Remove the right and left rear panels (see Rear panels).
  7. Remove the rear main frame (see Main rear frame).
  8. Lift the left side of the board first, and then pull the board out of the holder enough to access the connector (1).
  9. Disconnect the cable from the board (2), and then remove the board from the computer.
    Figure :
To install the power button board, reverse the removal procedures.
System board shield
The system board shield sits above the system board. It is secured with three screws.
To remove the system board shield:
  8. Remove the three screws that secure the shield to the computer (1).
  9. Disconnect the cable from the CONVER DB CONN system board connector (2).
  10. Lift the left side of the shield first (3), and then pull the shield up and off the system board.
    Figure :
To install the system board shield, reverse the removal procedures.
When replacing the shield, make sure to place the five tabs on the right side of the shield into their slots in the computer before placing the shield atop the system board.
Replacing the system board shield
Figure :
Speakers
Spare part number
Right speaker
652274-001
Left speaker
652275-001
The speakers are located at the bottom of the computer. Two separate speakers are each secured by two screws.
Speaker location
Figure :
To remove the speakers:
  8. Remove the system board shield (see System board shield).
  9. Disconnect the speaker cables from the system board connectors (1).
  10. Remove the speaker cables from their routing paths.
  11. Remove two screws (2) that secure each speaker to the computer.
  12. Lift the speakers straight up and out of the computer (3).
    Figure :
    Figure :
To install the speakers, reverse the removal procedures.
Infrared sensor board
Spare part number
652307-001
The infrared board is located on the bottom left side of the computer, under the left speaker. It is secured with one screw and has one connector.
Infrared board location
Figure :
To remove the infrared board:
  8. Remove the speakers (see Speakers).
  9. Disconnect the cable from the board (1) and remove the screw (2) that secures the board to the computer.
  10. Lift the board from the computer (3).
    Figure :
To install the infrared board, reverse the removal procedures.
Fan
Spare part number
Fan
652321-001
The fan is located near the top of the computer. It is secured with three screws. You do not have to remove the heat sink to remove it.
Fan location
Figure :
To remove the fan:
  9. Disconnect the fan cable from the system board connector (1).
  10. Remove the three screws that secure the fan to the computer (2).
  11. Lift the fan from the computer (3).
    Figure :
To install the fan, reverse the removal procedures.
Fan Sink (Thermal Module)
Spare part number
Fan sink (thermal module) for use in computers with discrete graphics
658987-001
Fan sink (thermal module) for use in computers with UMA graphics
658988-001
The fan sink is secured with four screws. You do not have to remove the chassis fan to remove the it.
Fan location
Figure :
To remove the fan sink:
  9. In the order indicated by the numbers stamped into the heat sink, remove the four screws (1) that secure the fan sink to the system board.
  10. Disconnect the fan cable from the system board (2).
  11. Slide the fan sink toward the top of the computer (3), and then lift it off the system board .
    Figure :
To replace the fan sink, reverse the removal procedures.
Processor
Spare part number
Intel Core i7 processor
2600 (3.4-GHz, 8-MB L3 cache)
638632-001
Intel Core i5 processors
2500 (3.3-GHz, 6-MB L3 cache)
638631-001
2400 (3.1-GHz, 6-MB L3 cache)
638630-001
2300 (2.8-GHz, 6-MB L3 cache)
654601-001
Intel Core i3 processors
2120 (3.3-GHz, 3-MB L3 cache)
638629-001
2100 (3.1-GHz, 3-MB L3 cache)
638628-001
Intel Pentium Dual-Core processors
G850 (2.9-GHz, 3-MB L3 cache)
655973-001
G840 (2.8-GHz, 3-MB L3 cache)
655972-001
G620 (2.6-GHz, 3-MB L3 cache)
655971-001
To remove the processor:
  9. Remove the fan sink (see Fan Sink (Thermal Module)).
  10. Rotate the locking lever to its full open position (1).
  11. Lift the processor cover (2).
  12. Carefully lift the processor from the socket (3).
    Do NOT handle the pins in the processor socket. These pins are very fragile and handling them could cause irreparable damage. Once pins are damaged it may be necessary to replace the system board.
    The heat sink must be installed within 24 hours of installing the processor to prevent damage to the processor’s solder connections.
    Figure :
To install a new processor:
  1. Place the processor in its socket and close the retainer.
  2. Secure the locking lever.
    If reusing the existing heat sink, go to step 3.
    If using a new heat sink, go to step 5.
  3. If reusing the existing heat sink, clean the bottom of the heat sink with the alcohol pad provided in the spares kit.
  4. Apply the thermal material provided in the spares kit to the top of the processor and install the heat sink atop the processor.
  5. If using a new heat sink, remove the protective covering from the bottom of the heat sink and place it in position atop the processor.
Hard drive connector
The hard drive connector is located near the middle of the computer. You must remove the stand bracket get to the connector's screws. It is secured with two screws and has two connectors. The cables are taped to the computer.
Hard drive connector location
Figure :
To remove the hard drive connector:
  8. Remove the stand bracket by removing the eight screws (1) that secure the bracket to the computer, and then lifting the bracket off the computer (2).
    Figure :
  9. Remove the tape (1) that secures the cables to the computer.
  10. Remove two screws (2) that secure the hard drive connector to the computer.
  11. Disconnect the cables from the system board (3).
    Figure :
  12. Remove the hard drive connector from the computer.
To install the hard drive connector, reverse the removal procedures.
Graphics board
Spare part number
GFX, 1 GB graphics card
652164-001
ATI MXM30 Viper 1-GB HD5570 graphics card
628380-001
The graphics board is located near the top of the system board under the fan sink. You must remove the fan sink to remove the graphics board. The board is secured with two screws.
Graphics board location
Figure :
To remove the graphics board:
  10. Remove two screws (1) that secure the board to the computer.
  11. Rotate the outer side of the board upward (2), and then remove it at an angle (3).
    Figure :
To install the graphics board, reverse the removal procedures.
Graphics boards are designed with a notch to prevent incorrect insertion.
WLAN module and TV tuner module
The procedures for removing the WLAN module and the TV tuner module are very similar. The modules install into different slots located next to each other. This section shows removing the WLAN module, but you can use the same basic procedure to remove the TV tuner module. The number of antennas connected to the module may vary.
Spare part number
Intel Centrino® Advanced-N 6205 802.11a/b/g/n
652165-001
HP WLAN combo 802.11b/g/n + Bluetooth 2.1 card
652279-001
802.11b/g/n
654602-001
HP TV tuner
613990-001
The WLAN module is located near the middle of the system board. The module is secured with two screws and has two connected antennas.
WLAN module location
Figure :
The TV tuner module is located toward the bottom of the system board near the memory sockets. The module is secured with two screws and has one antenna.
TV tuner location
Figure :
To remove the WLAN module:
  9. Disconnect the antenna cables from the module (1). The number of antenna cables may vary.
  10. Remove the screw (2) that secures the module to the computer.
  11. Lift the module to a 45-degree angle, and then remove it from the system board (3).
    Figure :
To install the WLAN module or TV tuner module, reverse the removal procedures.
WLAN modules and TV tuner modules are designed with a notch to prevent incorrect insertion.
System Board
Spare part number
System board
658978-001
The system board is located on the right side of the computer (when viewed from the rear). It is secured with seven screws.
System board location
Figure :
To remove the system board:
  9. Remove the fan (see Fan).
  10. Remove the fan sink (see Fan Sink (Thermal Module)).
  11. Remove the WLAN module and/or TV tuner module (see WLAN module and TV tuner module).
  12. Remove the graphics board (see Graphics board).
  13. Disconnect all cables from the system board, noting their location for reinstallation.
  14. Remove the seven screws (circled in image) that secure the system board to the computer.
  15. Lift the system board straight up and out of the computer.
    Figure :
To install the system board, reverse the removal procedures.
Display Panel
Spare part number
Display panel, 23-inch, ZBD
658981-001
Display, 23-inch, non-ZBD
658979-001
The display panel is secured to the frame with 10 screws. The panel is secured to the front bezel with 6 screws.
To remove the display panel:
  11. Remove the graphics board (see Graphics board).
  12. Remove the WLAN module and/or TV tuner module (see WLAN module and TV tuner module).
  13. Remove the system board (see System Board).
  14. Remove the 10 screws that secure the display panel to the computer. The number of screws per side is as follows:
    • Top: 2 screws
    • Bottom: 6 screws
    • Left: 1 screw
    • Right: 1 screw
    Figure :
  15. Separate the display panel from the computer.
  16. Remove the six screws that secure the display panel to the front bezel (3 screws per side).
    Figure :
  17. Lift the display panel from the front bezel.
To install a display panel, reverse the removal procedures.
G-sensor board
Spare part number
G-sensor board
658983-001
G-sensor cable
658984-001
The G-sensor board is mounted on the touchscreen glass. It senses when you tap on the glass, and it wakes the system if in standby mode. It is attached to the glass with adhesive.
G-sensor board location
Figure :
To remove the G-sensor board:
  12. Remove the WLAN module and TV tuner module (see WLAN module and TV tuner module).
  14. Remove the display (see Display Panel).
  15. Pry the board from the display.
    Figure :
To install the G-sensor board, reverse the removal procedures.
