    Fix Windows 10 Update Issues
HP Compaq 8200 Elite Small Form Factor PC - Removing and Replacing the Access Panel
This document is provided to assist in removing and replacing the access panel for the HP Compaq 8200 Elite Small Form Factor PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the access panel that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Side access panel
646815-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the access panel, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Access panel from the menu on the upper left hand side of the screen.
Click here to view the access panel removal video (right-click on the link to open in a new window/tab).
Access panel removal
  2. Pull up and hold the access panel release latch.
  3. Rotate the panel up and lift it away from the chassis.
Access panel replacement
  1. Slide the lip on the front end of the access panel under the lip on the front chassis guide rail.
  2. Lower the back end of the panel until it contacts the chassis.
  3. Press down on the access panel until it locks into place.
Parts return
