HP LaserJet Enterprise M4555 MFP Series - Replace the staple cartridge (for models with a stapler/stacker)
  1. Press the release latch, and then slide the stapler/stacker away from the product.
    Figure : Release the latch and slide the stapler away from the product
  2. Open the staple-cartridge door.
    Figure : Open the staple-cartridge door.
  3. Lift up on the staple-cartridge green handle, and then pull the cartridge out of the stapler to remove it.
    Figure : Remove the staple cartridge
  4. Insert a new staple cartridge, push down on it to snap it into place, and then close the staple-cartridge door.
    Figure : Install a new cartridge and close the stapler door
  5. Slide the stapler/stacker toward the product until it latches in place.
    Figure : Slide the stapler/stacker back to the product
