HP LaserJet Enterprise M4555 MFP Series - Load paper trays
Tray and bin capacity
Tray or bin
Paper type
Quantity
Tray 1
Paper
Range:
60 g/m2 bond to 200 g/m2 bond
Maximum stack height: 10 mm
Equivalent to 100 sheets of 75 g/m2 bond
Envelopes
Less than 60 g/m2 bond to 90 g/m2 bond
Up to 10 envelopes
Labels
Maximum 0.23 mm thick
Transparencies
Minimum 0.13 mm thick
Up to 50 sheets
Tray 2
Paper
Range:
60 g/m2 bond to 120 g/m2 bond
Maximum stack height: 56 mm
Equivalent to 500 sheets of 75 g/m2 bond
Maximum stack height for 10 x 15 cm size paper: 15 mm
Transparencies
Optional Trays 3, 4, and 5
Paper
Range:
Transparencies
Output bin
Paper
Range:
Up to 500 sheets of 75 g/m2 bond
Document feeder
Paper
Range:
60 g/m2 bond to 220 g/m2 bond
Up to 50 sheets of 75 g/m2 bond
Envelope feeder
Envelopes
Range:
Minimum: 90 mm x 148 mm
Maximum: 178 mm x 254 mm
  • COM 10
  • Monarch
  • B5 176 mm x 250 mm
  • C5 162 mm x 229 mm
  • DL 110 mm x 220 mm
Up to 75 envelopes
Top and middle output bins
Paper
Up to 125 sheets of 75 g/m2 bond
Bottom output bin
Paper
Range:
Up to 650 sheets of 75 g/m2 bond
Envelopes
Range:
Labels
Transparencies
Stapling/stacker
Paper
Stapling capacity: 30 sheets of 75 g/m2 bond
Bin capacity for staple jobs: 15 stapled jobs of 30 sheets of 75 g/m2 bond
Duplexer
Paper
Paper orientation for loading trays
If you are using paper that requires a specific orientation, load it according to the information in the following tables.
The Alternative Letterhead Mode and Image Rotation settings affect the way you load letterhead or preprinted paper. The following information depicts the default setting.
Paper orientation for loading Tray 1
Paper type
Single-sided printing, no stapler/stacker
Duplex printing, no stapler/stacker
Single-sided printing with the stapler/stacker
Duplex printing with the stapler/stacker
Letterhead, preprinted, or prepunched
Face-up
Top edge leading into the product
Figure : Paper orientation
Face-down
Bottom edge leading into the product
Face-up
Face-down
Envelopes
Face-up
Short, postage-edge leading into the product
Figure : Envelope orientation
Face-up
Paper orientation for loading Tray 2 or Trays 3, 4, and 5
Paper type
Duplex printing
Face-down
Top edge at the right of the tray
Face-up
Load Tray 1
To avoid jams, never add or remove paper from Tray 1 during printing.
  1. Open Tray 1.
    Figure : Location of Tray 1
  2. Pull out the tray extension to support the paper and set the side guides to the correct width.
    Figure : Location of the tray extension
  3. Load paper in the tray.
    Figure : Load paper
  4. Make sure the stack fits under the tabs on the guides and does not exceed the load-level indicators.
    Figure : Load-level indicators
  5. Adjust the side guides so that they lightly touch the paper stack but do not bend it.
    Figure : Load paper
Load Tray 2 and optional Trays 3, 4, and 5 with standard-size paper
  1. Open the tray.
    Do not open the tray while it is in use.
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
    Figure : Location of the paper size adjustment
  3. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure the top of the stack is below the tray full indicator.
    Figure : Load the paper
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
  4. Close the tray.
  5. The control panel shows the tray’s paper type and size. If the configuration is not correct, follow the instructions on the control panel to change the size or type.
    Figure : Control panel
Load Tray 2 and optional Trays 3, 4, and 5 with custom-size paper
  1. Open the tray.
  4. Close the tray.
    Figure : Location of Tray 3
  5. The control panel prompts you to set the paper size and type. Select the Custom setting, and then configure the X and Y dimensions of the custom paper size.
    See the label in the paper tray, or the following illustration, to determine the X and Y dimensions.
