    Windows 11 Upgrade Guide
HP Compaq 8200 Elite Convertible Minitower PC Product Specifications
Product image
Product features
Feature
Processor
  • Intel Core i7-2600 (3.40 GHz, 8MB cache, 4 cores)
  • Intel Core i5-2500 (3.30 GHz, 6MB cache, 4 cores)
  • Intel Core i5-2400 (3.10 GHz, 6MB cache, 4 cores)
  • Intel Core i3-2120 (3.30 GHz, 3MB cache, 2 cores)
  • Intel Core i3-2100 (3.10 GHz, 3MB cache, 2 cores)
Intel Q67 Express
Memory slots
4 DIMM
Standard memory
4GB 1333 MHz DDR3 SDRAM
Storage
Internal drive bays:
Three 8.9 cm (3.5 in)
External drive bays:
Three 13.3 cm (5.25 in)
Internal drives:
  • SATA (7200 rpm):
    Up to: 1TB
  • SATA (10000 rpm):
  • SATA Solid State Drive (SSD):
  • SATA SED (7200 rpm):
    Up to: 320GB
Optical drives:
  • SATA SuperMulti LightScribe DVD writer
  • SATA DVD-ROM
Ports
  • 10 USB 2.0
  • 1 serial (optional)
  • 1 parallel (optional)
  • 1 eSATA (optional)
  • 1 DisplayPort
  • 1 VGA video
  • 1 PS/2 keyboard
  • 1 PS/2 mouse
  • 1 RJ-45
  • 1 microphone/headphone jack
  • 1 line in
  • 1 line out
  • DVI output available via optional DisplayPort to DVI Adapter
Slots
  • 3 full-height PCI
  • 1 full-height PCIe x1
  • 2 full-height PCIe x16
Audio
Realtek ALC261 high definition audio codec (all ports are stereo)
  • Integrated Intel 82579LM Gigabit Ethernet
  • Intel Pro 1000 CT Gigabit
Graphics
Integrated Intel HD
Electrical specifications
Feature
Standard efficiency
320 W active PFC
High efficiency1
320 W active PFC 87%/90%/87% efficient at 20%/50%/100% load
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
5.5 A
Rated input current with Energy Efficient1 power supply
5.5 A
Current leakage (NFPA 99)
<450 µA
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Physical specifications
Feature
Chassis (H x W x D)
448 x 178 x 445 mm (17.6 x 7.00 x 18.0 in)
System volume
35.4 L (2160 cu in)
Packaging (H x W x D)
575 x 323 x 620 mm (22.6 x 12.7 x 24.4 in)
System weight
11.2 kg ( 24.5 lb)
Shipping weight
15.4 kg (34.0 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Software/OS
Feature
  • Genuine Windows 7 Professional 32
  • Genuine Windows 7 Professional 64
  • Genuine Windows 7 Home Basic 32
  • Genuine Windows Vista Business 32
  • Genuine Windows Vista Home Basic 32
  • FreeDOS
Pre-installed software included with all models except those with FreeDOS operating system:
  • HP ProtectTools Security Suite
  • HP Software Management Agent
  • Computrace for Desktops agent
  • HP Vision Diagnostics
  • PDF Complete Corporate Edition
  • Microsoft Office 2010 preloaded (purchase of a Product Key required to activate a full Office 2010 suite)
Environmental specifications
Feature
Temperature range
  • Operating:
    10° to 35°C ( 50° to 95°F)
  • Non-operating:
    -30° to 60°C (-22° to 140°F)
Relative humidity
  • Operating:
    10% to 90% (non-condensing at ambient)
  • Non-operating:
    5% to 95% (non-condensing at ambient)
 Maximum altitude   (unpressurized)
  • Operating:
    3048 m (10,000 ft)
  • Non-operating:
    9144 m ( 30,000 ft)
Safety certifications
Feature
Hardware certifications
  • FCC
  • B
  • CE
  • TUV- cTUVus Mark Canada and United States
  • TUV- GS Mark for European Union
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x.
  • WPA-PSK and TKIP WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
