HP Compaq 6200 Pro Small Form Factor PC Product Specifications
Product description
The HP Compaq 6200 Pro includes (6) USB 2.0 ports, serial port, PS/2 mouse and keyboard ports, RJ-45 network interface, DisplayPort v1.1a, VGA video interfaces, and 3.5 mm audio in/out jacks with Intel Q65 Express chipset.
Product features
Feature
Processor
  • Intel Core i7-2600 (3.40 GHz, 8MB cache, 4 cores)
  • Intel Core i5-2500 (3.30 GHz, 6MB cache, 4 cores)
  • Intel Core i5-2400 (3.10 GHz, 6MB cache, 4 cores)
  • Intel Core i3-2120 (3.30 GHz, 3MB cache, 2 cores)
  • Intel Core i3-2100 (3.10 GHz, 3MB cache, 2 cores)
Intel Q65 Express
Memory slots
4 DIMM
Memory, maximum
16GB 1333 MHz DDR3 SDRAM
Ports
  • 10 USB 2.0
  • 1 serial (optional)
  • 1 PS/2 keyboard
  • 1 PS/2 mouse
  • 1 DisplayPort
  • 1 VGA
  • 1 DVI
  • 1 microphone/headphone jack
  • 1 line in
  • 1 line out
  • 1 parallel (optional)
  • 1 eSATA (optional)
  • 1 RJ-45
Slots
  • 1 low-profile PCI
  • 2 low-profile PCIe x1
  • 1 low-profile PCIe x16
  • Integrated Intel 82579LM Gigabit Ethernet
  • Intel Gigabit CT Desktop (optional)
  • 802.11 b/g/n wireless
Storage
External drive bays:
  • One 3.5 in
  • One 5.25 in
Internal drive:
  • SATA (7200 rpm):
    Up to: 1TB
  • SATA (10000 rpm):
    Up to: 160GB
  • Solid State Drive (SSD):
    Up to: 160GB
  • 3.5-inch Removable SATA (7200 rpm):
    Up to: 500GB
Optical drive:
  • SATA Blu-ray writer
  • SATA SuperMulti LightScribe DVD writer
  • SATA DVD-ROM
Graphics
  • Integrated Intel HD
  • AMD FirePro 2270 (512MB)
  • AMD Radeon HD 6350 (512MB)
  • AMD Radeon HD 6450 (512MB)
  • NVIDIA Quadro NVS 295 (256MB)
  • NVIDIA Quadro NVS 300 (512MB)
  • HP DisplayPort to VGA adapter
  • HP DisplayPort to DVI-D adapter
  • HP DisplayPort to HDMI adapter
Electrical specifications
Feature
Standard efficiency
240 W active PFC
High efficiency1
240 W active PFC 87%/90%/87% efficient @ 20%/50%/100% load
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
4 A
Rated input current with Energy Efficient1 power supply
4 A
Current leakage
<275 µA
Power supply
  • 240 W power supply - active PFC
  • 240 W 90% efficient power supply - active PFC
Power supply fan
92 mm variable speed
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Physical specifications
Feature
Chassis (H x W x D)
100 x 338 x 379 mm (4.0 x 13.3 x 14.9 in)
System volume
13.0 L (790.3 cu in)
Tower stand (H x W x D)
29 x 178 x 200 mm (1.1 x 7.0 x 7.9 in)
Packaging (H x W x D)
229 x 500 x 594 mm (9.0 x 19.7 x 23.4 in)
System weight
7.6 kg (16.7 lb)
Shipping weight
8.1 kg (17.9 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Software/OS
Feature
  • Genuine Windows 7 Professional 32-bit
  • Genuine Windows 7 Professional 64-bit
  • Genuine Windows 7 Home Premium 32-bit
  • Genuine Windows 7 Home Premium 64-bit
  • Genuine Windows 7 Home Basic 32-bit
  • Genuine Windows Vista Business 32-bit
  • Genuine Windows Vista Home Basic 32-bit
  • Novell SUSE Linux Enterprise Desktop 11
  • FreeDOS
Software installed
Included with all models except those configured with FreeDOS:
  • HP Software Management Agent
  • HP Insight Diagnostics
  • PDF Complete
Manageability features
  • HP Client Automation Starter
  • HP SoftPaq Download Manager
  • HP Client Catalog for Microsoft SMS
  • HP Systems Software Manager
Environmental specifications
Feature
Temperature range
Operating:
0° to 85°C (32° to 185°F)
Non-operating:
-30° to 60°C (-22° to 140°F)
Relative humidity
Operating:
10% to 90% (non-condensing at ambient)
Non-operating:
5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
Operating:
3048 m (10,000 ft)
Non-operating:
9144 m (30,000 ft)
Safety certifications
Feature
Eco-Label certifications
  • US ENERGY STAR
  • IT ECO declaration
  • EPEAT Gold where HP registers commercial desktop products
Hardware certifications
  • FCC
  • B
  • CE
  • TUV- cTUVus Mark Canada and United States
  • TUV- GS Mark for European Union
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM 802.1x authentication
  • WPA: 802.1x.
  • WPA-PSK and TKIP WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
