HP ProBook 6360b Notebook PC - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
33.7 x 322 x 220 mm (1.32 x 12.68 x 8.66 in)
  • Starting at 1.90 kg (4.19 lb) with hard drive and weight saver (no optical drive)
  • Starting at 2.02 kg (4.46 lb) with hard drive and DVD-ROM drive
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 3-cell battery and WLAN.
Electrical specifications
Specification
Stand-alone power requirements (ac power)
Nominal operating voltage
18.5 V
Max operating power
<65 W or <90 W
Environmental specifications
Specification
Temperature
Operating:
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating:
  • -20° to 60°C (-4° to 140°F)
Relative humidity
Operating:
  • 10% to 90%, non-condensing
Non-operating:
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating:
  • 125 g, 2 ms, half-sine
Non-operating:
  • 200 g, 2 ms, half-sine
Random vibration
Operating:
  • 0.75 g
Non-operating:
  • 1.50 g
Altitude (unpressurized)
Operating:
  • -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
  • -15.24 to 12,192 m (-50 to 40,000 ft)
Audio/Visual
Specification
Audio/Visual
  • SRS Premium Sound
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
  • Optional 720 p HD webcam
    • HD format (widescreen)
    • Supports videoconferencing and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280 x 720 resolution (720 p) and up to 30 frames/s
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low light sensitivity
    • Improved dynamic range
Safety certifications
Specification
Standard features
  • HP ProtectTools Security Manager (Standard modules include):
    • Credential Manager
    • Computrace Pro
    • Device Access Manager
    • Drive Encryption
    • Face Recognition (Webcam configurations only)
    • File Sanitizer
    • Privacy Manager
    • Embedded Security
  • Enhanced Pre-Boot Security (Multiuser/Multifactor)
  • HP SpareKey
  • One-Step Logon
  • TPM 1.2 Embedded Security Chip
  • HP Disk Sanitizer
  • Security lock slot
  • Support for Intel AT
Optional features
  • Smart Card Reader (replaces ExpressCard/54 slot)
  • HP Fingerprint Sensor
  • HP Privacy Filter
  • Computrace Pro for HP ProtectTools with GPS Tracking
Country: Flag Thailand
