HP L1506x 15-inch LED Monitor - Specifications
Physical specifications
Feature
Dimensions (H x W x D)
  • Unpacked w/stand: 20.3 x 35.5 x 34.0 cm (7.9 x 13.9 x 13.4 in)
  • Unpacked w/o stand (head only): 6.0 x 29.0 x 34.0 cm (2.4 x 11.4 x 13.4 in)
  • Packaged: 15.0 x 39.5 x 39.5 cm (5.9 x 15.6 x 15.6 in)
  • Unpacked: 3.10 kg (6.83 lb)
  • Packaged: 4.35 kg (9.59 lb)
Tilt range
-5° to +30° vertical tilt
Swivel range
None
Height adjustable
No
Pivot rotation
No
Base
Detachable
Panel specifications
Feature
Type
TN
38.1 cm (15 in)
Screen opening (W x H)
30.74 x 23.13 cm (12.1 x 9.1 in)
Aspect ratio
4:3
Viewing angle (typical)
160° horizontal/140° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
400 nits (cd/m2)
Contrast ratio (typical)1
700:1
Dynamic contrast ratio (typical)1
1,000,000:1
Response time (typical)1
8 ms (On/Off)
Pixel pitch
0.0297 (H) × 0.0297 cm (V)
Backlight lamp life (to half brightness)
50,000 hours typical
Color gamut (typical)
60%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls
Feature
Buttons or switches
  • 3-button OSD (menu, minus, plus)
  • Power On/Off
Languages
  • English
  • French
  • German
  • Italian
  • Dutch
  • Spanish
  • Netherlands
  • Japanese
  • Portuguese
  • Traditional Chinese
  • Simplified Chinese languages
User controls
  • Brightness
  • Contrast
  • Color
  • Image Control
  • OSD Control
  • Management
  • Language
  • Factory Reset
  • Exit
Signal interface/performance
Feature
Horizontal frequency
30 to 63 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1024 x 768 @ 60 Hz (recommended)
Preset VESA graphic modes (non-interlaced)
  • 1024 x 768 @ 60 Hz, 70 Hz, and 75 Hz
  • 832 x 624 @ 75 Hz, 800 x 600 @ 60 Hz, 72 Hz, and 75 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz, 72 Hz, and 75 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
80 MHz
User programmable modes
Yes (20)
Anti-glare
Yes
Default color temperature
Warm (6500 K)
Video/Other inputs
Feature
Plug and play
Yes
Input signal
15 pin D-sub (Analog VGA)
Input impedance
75 ohms (2% value change allowed)
Sync input
TTL separate synch
Video cable
Detachable 15-pin D-sub
Video cable length
1.8 m (70.8 in)
Electrical specifications
Feature
Input power
100 to 240 V ac
Typical power consumption
<10 W
Maximum
<15.0 W
Power saving
<1.0 W
Power cable length
1.9 m (74.8 in); detachable
Environmental specifications
Feature
Operating temperature
0° to 50°C (32° to 122°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 90%
Operating altitude
0 to 5,000 m (0 to 16,400 ft)
Non-operating altitude
0 to 12,100 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass1
Yes
BFR/PVC free
Plastics and finishes or paint
Mercury free
Yes
1: Arsenic and its compounds were not detected using US EPA Test Methods 3052 & 3052/6010b by ICP or ICP-AES.
Country: Flag Thailand
