HP LaserJet P3005 Printer Series - Replace the EIO Jetdirect Card
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
EIO Jetdirect card replacement
  1. Turn off the device.
  2. Disconnect the network cable from the EIO card.
  3. Loosen the two screws from the EIO card, and then remove the EIO card from the EIO slot.
  4. Install the new EIO card in the EIO slot and tighten the screws.
  5. Connect the network cable to the EIO card.
  6. Turn on the device, and then print a configuration page to verify that the new EIO device is recognized.
    When you print a configuration page, an HP Jetdirect configuration page that contains network configuration and status information also prints.
Parts return
