HP LaserJet Enterprise P3015 Printer Series - Replace the HP Jetdirect Print Server Card
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
HP Jetdirect print server card replacement
  1. Turn off the product.
  2. Disconnect any cables from the EIO card.
  3. Remove the two screws and cover plate from the EIO slot on the back of the product.
  4. Remove the EIO card from the EIO slot.
  5. Install the new EIO card in the EIO slot and tighten the screws.
  6. If the EIO card requires a cable connection, connect the cable.
  7. Turn on the product, and then print a configuration page to verify that the new EIO card is recognized.
    When you print a configuration page, an HP Jetdirect configuration page that contains network configuration and status information also prints.
Parts return
