HP LaserJet 3390 and 3392 All-in-One Printer Series - Replace the Cassettes
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Cassette removal
  1. Pull out tray 2 or tray 3.
  2. Remove the new cassette from the package. Place the used cassette in the package for recycling. See the enclosed recycling guide for recycling instructions.
  3. Remove all orange packing material from the tray.
  4. Adjust the media guides to the size of the media.
  5. Place the media in the tray.
    Do not fan the media before placing it in the tray.
  6. Slide tray 2 or tray 3 into the all-in-one.
Parts return
