HP LaserJet 3390 and 3392 All-in-One Printer Series - Replace the Separation Pad
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Separation pad replacement
  1. Remove tray 2 or tray 3.
  2. Locate the separation pad.
  3. Remove two screws.
  4. Remove the separation pad.
    Before you remove the separation pad, take note of how it is positioned in the tray.
  5. Install the replacement separation pad.
  6. Replace the two screws, and return the tray to the all-in-one.
Parts return
