HP Color LaserJet CP3505 Printer Series - Replace the Fuser
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Fuser replacement
The fuser might be hot. Wait for the fuser to cool before you remove it.
  1. Open the upper (top) cover (fuser door).
  2. Squeeze the two blue fuser locking levers to release the fuser.
  3. Rotate the fuser up and out of the printer.
  4. Slide the new fuser into the device.
  5. Close the fuser door.
Parts return
