HP Color LaserJet 4700/CP4005 Series Printers - Replace the Tray 1 Separation Pad and Roller
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, Select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Separation pad and roller removal
  1. Remove the paper tray (Tray 2).
  2. Slide the tabs inward (callout 1).
  3. Pull the cover down and remove it.
  4. Pull the tabs on the roller outward (callout 2) and remove the roller.
    Reinstallation tip: Be sure that the fan is installed so that the label side faces the printer (callout 7). Align the cable as shown (callout 8). Ensure that the tabs on the roller (callout 3) are aligned and snap into place.
  5. To replace the separation pad, push down on the pad (callout 4) and then release the tab (callout 5) with a flat-blade screwdriver. Remove the separation pad.
  6. Install the new separation pad, ensuring that it snaps into place.
  7. To reinstall the cover, make sure the tabs (callout 6) are aligned properly. Push upward to close the cover, and then slide the tabs (callout 7) outward to lock the cover.
  8. Replace the paper tray.
Parts return
