    Windows 11 Upgrade Guide
HP LaserJet Pro 100 Color MFPs (M175a and M175nw) - Resolving Print Cartridge Error Messages
Control panel message
Recommended action
10.0004 Supply Error
10.1004 Supply memory error
There is a communication failure with the imaging drum.
  • Turn the product off and then on.
  • If the error persists, replace the imaging drum.
  • If the error persists, contact HP. See www.hp.com/support/LJColorMFPM175 or the support flyer that came in the product box.
10.000X Supply memory error
10.100X Supply memory error
There is a communication failure with one of the print cartridges. "X" indicates which cartridge: 0=black, 1=cyan, 2=magenta, 3=yellow.
  • Verify that the print cartridge is installed correctly. Remove and reinstall the print cartridges.
  • If the error persists, replace the print cartridges.
Black cartridge is low
The print cartridge is nearing the estimated end of its useful life.
Printing can continue, but consider having a replacement supply on hand.
Black cartridge is very low
The print cartridge is at the estimated end of its useful life.
To ensure optimal print quality, HP recommends replacing the print cartridge at this point. You can continue printing until you notice a decrease in print quality. Actual cartridge life may vary.
Once an HP supply has reached “very low”, HP's premium Protection Warranty on that supply has ended. All print defects or cartridge failures incurred when an HP supply is used in continue at very low mode will not be considered to be defects in materials or workmanship in the supply under the HP Print Cartridge Warranty Statement.
Cyan cartridge is low
Cyan cartridge is very low
Door open
The print cartridge door is open.
Close the print cartridge door.
Jam in cartridge area
The product has detected a paper jam in the print cartridge area.
Clear the jam from the area indicated in the message, and then follow the control panel instructions.
Magenta cartridge is low
Magenta cartridge is very low
Replace <Color> Cartridge
The indicated print cartridge is at the estimated end of its useful life. The product is customer-configured to stop when the print cartridge level is very low.
Replace the print cartridge, or reconfigure the product to continue printing after the print cartridge reaches the “very low” level.
Replace <Color>. Printing Black.
The indicated print cartridge is at the estimated end of its useful life. The product is customer-configured to print with the black cartridge only, until the very low print cartridge is replaced.
Replace Supplies
Multiple supplies are at the estimated end of their useful life, and the product is customer-configured to stop when the supply level is very low.
Replace the supplies, or reconfigure the product to continue printing after the supplies reach the “very low” level.
Replace Supplies. Printing Black.
One or more of the print cartridges is at the estimated end of its useful life. The product is customer-configured to print with the black cartridge only, until the very low print cartridges are replaced.
Supplies are low
One or more of the print cartridges, or a combination of print cartridge(s) and the imaging drum, are nearing the estimated end of their useful life.
Supplies are very low
One or more of the print cartridges, or a combination of print cartridge(s) and the imaging drum, have reached the estimated end of their useful life.
To ensure optimal print quality, HP recommends replacing the print cartridge or imaging drum at this point. You can continue printing until you notice a decrease in print quality. Actual cartridge life may vary.
Once an HP print cartridge has reached “very low”, HP's premium Protection Warranty on that supply has ended. All print defects or cartridge failures incurred when an HP supply is used in continue at very low mode will not be considered to be defects in materials or workmanship in the supply under the HP Print Cartridge Warranty Statement.
The imaging drum installed in this product is covered by the product warranty. Replacement imaging drums have a one-year limited warranty from the date of installation. The imaging drum installation date displays on the supplies status page.
Supplies in wrong positions
The print cartridges are installed in the incorrect slots.
Make sure that each print cartridge is installed in the correct slot.
Used <color> cartridge is installed
A used supply has been installed. The print cartridge is most likely a refilled cartridge.
If you believe you purchased a genuine HP supply, visit this HP Web address: www.hp.com/go/anticounterfeit.
If product failure or damage is attributable to the use of a non-HP print cartridge or refilled print cartridge, HP will charge its standard time and materials charges to service the product for the particular failure or damage. Supply status and features that depend on it are unavailable with used cartridges.
Used cartridges installed
Used supplies have been installed. The print cartridges are most likely refilled cartridges.
Used supplies in use
Wrong Cartridge in <Color> Slot
A print cartridge is installed incorrectly in the indicated slot.
Yellow cartridge is low
Yellow cartridge is very low
