This document is for HP Deskjet Ink Advantage 2060 All-in-One printers.
- ${title}
- ${title}
- ${title}
- ${title}
HP Deskjet Ink Advantage 2060 Printers - Description of the Control Panel
1 On: Turns the product on or off. When the product is off, a minimal amount of power is still used. To completely remove power, turn off the product, then unplug the power cord.
2 Cancel: Stops the current operation.
3 Resume: Instructs the HP Printer to continue after a problem is solved.
4 Printer display: Displays printer status and current estimated ink levels.
5 Attention light: Signals if there is an error, indicating a user action is required.
6 Printer icon: Signals a carriage stall, the carriage door should be closed, or the output tray should be opened.
7 Output tray icon: Signals that the output tray should be opened.
8 Ink drop icon: Signals a problem with one or both cartridges.
9 Ink gauge icons: Displays estimated current ink levels and signals when there are cartridge problems.Ink level warnings and indicators provide estimates for planning purposes only. When you receive a low-ink warning message, consider having a replacement cartridge available to avoid possible printing delays. You do not have to replace the cartridges until the print quality is unacceptable.
10 Paper icon: Signals printer is out of paper or there is a paper jam.
Figure : Graphic - The control panel of the HP Deskjet Ink Advantage 2010 Printer (K010)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
