HP Color LaserJet Enterprise CP5520 and HP Color LaserJet Enterprise M750 - Supported paper sizes
This product supports a number of paper sizes, and it adapts to various media.
To obtain best print results, select the appropriate paper size and type in your print driver before printing.
Supported paper and print media sizes
Size
Dimensions
Tray 1
Tray 2
Tray 3, optional trays 4, 5, and 6
Letter1
216 x 279 mm
Legal
216 x 356 mm
A41
210 x 297 mm
RA4
215 x 305 mm
SRA4
225 x 320 mm
Executive
184 x 267 mm
A3
297 x 420 mm
A5
148 x 210 mm
2
A6
105 x 148 mm
B4 (JIS)
257 x 364 mm
B5 (JIS)
182 x 257 mm
B6 (JIS)
128 x 182 mm
8k
270 x 390 mm
260 x 368 mm
273 x 394 mm
16k
184 x 260 mm
195 x 270 mm
197 x 273 mm
8.5 x 13 (Folio)
216 x 330 mm
Index card
76 x 127 mm3
101.6 x 152 mm
127 x 177.8 mm
127 x 203 mm
Statement
139.7 x 216 mm
10 x 15 cm
100 x 150 mm
11 x 17 (Tabloid)
279 x 432 mm
12 x 18 (Arch B)
305 x 457 mm
RA3
305 x 430 mm
SRA3
320 x 450 mm
Custom
Minimum: 76 x 127 mm
Maximum: 312/320 x 470 mm3
Minimum: 148 x 182 mm
Maximum: 297 x 432 mm
Minimum: 210 x 148 mm
1These sizes can be loaded in a rotated orientation in Tray 2, Tray 3, and optional Trays 4, 5, and 6.
2A5 size is supported for Tray 3 only, as a custom size, with the long edge feeding into the product first. A5 size is not supported for two-sided (duplex) printing from Tray 3.
3Custom media width is limited to 312 mm. However, SRA3, which is 320 mm wide, is supported. The maximum printable image is 302 mm wide. With the required blank 5 mm margins on each side for printing, any media wider than 312 mm will have its image centered and limited to 302 mm wide.
Supported envelopes and postcards
Size
Dimensions
Tray 1
Tray 2
Envelope #9
98.4 x 225.4 mm
Envelope #10
105 x 241 mm
Envelope DL
110 x 220 mm
Envelope C5
162 x 229 mm
Envelope C6
114 x 162 mm
Envelope B5
176 x 250 mm
Envelope Monarch
98 x 191 mm
Postcard
100 x 148 mm
Double postcard
148 x 200 mm
Supported paper sizes for duplex printing
  • Minimum: 148 x 182 mm
  • Maximum: 312/320 x 457 mm
For automatic duplexing, do not load paper that is heavier than 120 g/m2. Use manual duplexing to print on heavier paper.
