Order supplies and paper
Order genuine HP parts or accessories
Order through service or support providers
Contact an HP-authorized service or support provider.
Order using HP software
Use the HP Embedded Web ServerUse the HP Embedded Web Server
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Enterprise CM4540 MFP Product Series - Product supplies and accessories
Order parts, accessories, and supplies
Part numbers
Accessories
Item
HP Color LaserJet 500-sheet Paper Feeder and Cabinet
500-sheet paper tray with a storage cabinet.
CC422A
HP Color LaserJet 3 x 500-sheet Paper Feeder and Stand
1500-sheet paper tray. Contains three 500-sheet trays and a stand.
CC423A
HP LaserJet 900-sheet 3-bin Stapling Mailbox
Stapler with a 3-bin output mailbox that holds up to 900 sheets.
CC424A
500-sheet input tray (no storage cabinet or stand)
CC425A
HP LaserJet MFP Analog Fax Accessory 500
Provides fax capability for the product. This is included with the CM4540f MFP and CM4540fskm MFP models.
CC487A
Cables and interfaces
Item
Enhanced I/O (EIO) card
HP Jetdirect 635n IPv6/IPsec Print Server
J7961G
USB cable
2-meter standard USB-compatible device connector
C6518A
Customer self-repair parts
The following Customer Self-Repair parts are available for your product.
Parts listed as Mandatory self-replacement are to be installed by customers, unless you are willing to pay HP service personnel to perform the repair. For these parts, on-site or return-to-depot support is not provided under your HP product warranty.
Parts listed as Optional self-replacement may be installed by HP service personnel at your request for no additional charge during the product warranty period.
note:For more information, go to www.hp.com/go/learnaboutsupplies.
Item
Self-replacement options
Part number
HP Color LaserJet black print cartridge
Standard black cartridge
Mandatory
CE260A
CE260-67901
High-capacity black cartridge
Mandatory
CE264X
CE264-67901
HP Color LaserJet cyan print cartridge
Cyan cartridge
Mandatory
CF031A
CF031-67901
HP Color LaserJet yellow print cartridge
Yellow cartridge
Mandatory
CF032A
CF032-67901
HP Color LaserJet magenta print cartridge
Magenta cartridge
Mandatory
CF033A
CF033-67901
HP Color LaserJet Toner Collection Unit
Receptacle for toner that has not fused to the paper.
Mandatory
CE265A
CC493-67913
HP Staple cartridge
Replacement staple cartridge, which holds 5,000 staples
Mandatory
C8091A
HP Color LaserJet fuser kit
Replacement fuser
Mandatory
110 Volt fuser: CE246A
200 Volt fuser: CE247A
110 Volt fuser: CC493-67911
200 Volt fuser: CC493-67912
Fuser cleaning kit
Includes 50 sheets of HP LaserJet Tough Paper and instructions to clean the fuser
Mandatory
CC419-67905
Document feeder maintenance kit
Includes a replacement roller assembly and separation pad for the document feeder
Mandatory
CE248A
CE248-67901
HP Color LaserJet image transfer kit
Replacement transfer unit, transfer roller, Tray 1 pickup roller, and eight feed and separation rollers for Trays 2-5.
Mandatory
CE249A
CC493-67910
Repair maintenance kit
Replacement transfer unit and transfer roller
Mandatory
CC493-67909
Control panel kit
Replacement control panel
Optional
CC419-67901
Replacement stapler/stacker
Mandatory
CC424A
CC424-67901
Mandatory
CC425A
CC425-67901
Mandatory
CC422A
CC493-67902
Mandatory
CC423A
CC493-67903
Mandatory
CC487A
CC456-60002
Feed roller and separation roller kit for Trays 2–5
One feed roller and eight separation rollers
Mandatory
CC493-67907
Tray 1 roller kit
Pickup roller for Tray 1
Mandatory
CC493-67906
Formatter assembly kit
Replacement formatter (requires you to exchange the previous formatter)
Mandatory
CE871-69001
Internal hard disk assembly kit
Replacement HP Encrypted High Performance Hard Disk
Mandatory
CC419-67902
Output bin bezel
Replacement bezel for using the standard output bin
Mandatory
CC419-67904
Document feeder bin extension
Replacement long-paper extension for the document feeder output bin
Mandatory
CC419-67903
Secondary transfer roller kit
Replacement roller
Mandatory
CC493-67908
Document feeder feed roller
Replacement roller
Mandatory
PF2309K131NI
Document feeder pickup roller
Replacement roller
Mandatory
PF2309K132NI
Document feeder separation pad
Replacement separation pad
Mandatory
PF2309K133NI
Document feeder separation pad spring
Replacement spring
Mandatory
PF2309P322NI
Tray 2, 3, 4, or 5
Replacement paper cassette
Mandatory
RM1-5928-000CN
Pickup roller for Trays 2–5
Replacement roller
Mandatory
RL1-2099-000CN
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
