HP Scanjet Enterprise 7500 - Clear jams from the scanner paper path
To clear a paper jam:
  1. Open the automatic document feeder (ADF) hatch.
    Figure : Open the ADF hatch
  2. Remove the originals or any obstructions from the paper path.
    Use the green thumb wheel on the left side of the open hatch to manually advance originals through the paper path.
  3. Remove the ADF duplex background, remove any debris, and then slide the component back into its housing until it clicks into place.
    Figure : Remove ADF duplex background
  4. Close the ADF hatch until it snaps into place.
  5. Reload the unscanned originals in the document feeder.
  6. Resume scanning.
