HP Scanjet Enterprise 7500 - Replace the front panel
The scanner software CD which came with your product includes an animation which guides you through removing and replacing the front panel. This animation is also available at www.hp.com/support.
To replace the front panel, follow these steps:
  1. Press the Power () button to turn off the scanner, and then disconnect the USB cable and power supply from the scanner.
  2. Raise the scanner lid.
  3. Loosen the front panel cover.
    1. Locate the access hole on the underside of the front panel, and press the bottom end of a pen upward into the hole.
    2. While pressing the pen upward, use your fingers to gently pry at the tab location shown, lifting the front panel gently as you release the tab.
    Figure : Press end of pen into front panel access hole and pry to release tab
  4. Continue to pry at the remaining tab locations, lifting the front panel gently as you release each tab.
    Figure : Pry and release remaining front panel tabs
  5. Invert the front panel, hold it firmly with one hand, disconnect the 6–pin connector, and set the front panel aside.
    Figure : Disconnect 6–pin connector
  6. Connect the new front panel, taking care to align the notches on the 6–pin connector with the 6–pin receptacle on the front panel.
    Figure : Connect 6–pin connector
  7. Invert the front panel so that it is LCD side up, and position the front panel horizontally to the front panel bezel so the four tabs on the front panel align with the tab slots on the scanner.
    Figure : Align new front panel
  8. Gently push the front panel against the bezel (ensuring that the entire front panel is aligned properly), rotate down, and then press down on the front panel to seat it in place.
    Figure : Snap front panel into place
  9. Close the scanner lid, reconnect the USB and power cable, and then turn on the scanner.
Country: Flag Thailand
