Document ID: c02546032
Version: 1
HP ProBook 6450b Notebook PC and HP ProBook 6550b Notebook PC System BIOS Update F.04
Release date : 08-Oct-2010
Last updated : 09-Nov-2010
รายละเอียดการเปลี่ยนแปลง
New features:
  • Updated Intel Memory Reference Code (MRC) to version 1.4 to align with the latest Intel MRC code release.
  • Added a "DriveLock password on restart" option to the F10 Computer Setup utility to allow users to enable or disable a prompt for the DriveLock password when restarting the computer.
Field issue fixes:
  • Fixed an issue where the computer hangs during boot if legacy USB devices (external keyboard and mouse) are attached to the system.
  • Fixed an issue where the computer will not respond after Disable and Enable 1394 in the F10 Computer Setup utility.
  • Fixed an issue where the computer does not boot from a bootable CD if an external CD/DVD is used.
  • The time required for the Disk Sanitizer process has been shortened.
  • Removed the warning message about the computer not having a WLAN card installed.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
DATE OF CHANGE
Effective date : 15-Nov-2010
Hardware platforms affected : HP ProBook 6450b Notebook PC, HP ProBook 6550b Notebook PC
