Document ID: c02535420
Version: 1
HP EliteBook 8740w Mobile Workstation System BIOS Update F.09
Release date : 29-Sep-2010
Last updated : 29-Sep-2010
รายละเอียดการเปลี่ยนแปลง
New features:
  • Added a "DriveLock password on restart" option to allow users to enable or disable a prompt for the DriveLock password when restarting the computer.
  • Added an option to disable the ability to boot from USB devices, a notebook expansion bay, or a dock upgrade bay.
Field issue fixes:
  • Fixed an issue where the computer does not boot from a bootable CD if an external USB CD/DVD drive is used.
  • The time it takes for the Disk Sanitizer process has been shortened.
  • Moved the System Management BIOS (SMBIOS) table to accommodate the way certain third-party programs addess the SMBIOS memory.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None
Components affected:
DATE OF CHANGE
Effective date : 18-Oct-2010
Hardware platforms affected : HP EliteBook 8740w Mobile Workstation
