HP EliteBook 8540p Notebook PC - Removing and Replacing the Display Assembly
This document is provided to assist in removing and replacing the display assembly for the HP EliteBook 8540p Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small Torx T8 screwdriver
  • Small, Phillips-head (P00 and P1) screwdrivers
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the display assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
15.6-inch HD LED AntiGlare display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models without a webcam
595736-001 (Modified)
Yes
15.6-inch HD LED AntiGlare display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models with a webcam
595737-001 (Modified)
Yes
15.6-inch HD+ LED Wide Viewing Angle (WVA) display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models without a webcam
595739-001 (Modified)
Yes
15.6-inch HD+ LED display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models with a webcam
595740-001 (Modified)
Yes
15.6-inch FHD LED display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models without a webcam
595738-001 (Modified)
Yes
15.6-inch FHD LED display assembly - Includes three WLAN antenna transceivers with cables and two WWAN antenna transceivers with cables - For use on 8540p models with a webcam
600755-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the display assembly, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Display assembly from the menu on the upper left hand side of the screen.
Click here to view the display assembly removal video (right-click on the link to open in a new window/tab).
Display assembly removal
  2. On the bottom of the notebook, remove the two 6 mm T8 Torx screws from the rear corners of the notebook that secure the display assembly to the base enclosure.
    Under warranty, the display assembly is replaced as a whole unit. For out of warranty purposes, the individual internal components can be replaced to reduce customer repair costs.
  3. Remove the 4 mm P1 Phillips-head screw in the battery bay that secures the display assembly to the base enclosure.
  4. On the rear of the notebook, remove the two rubber screw covers from the corners of the notebook.
  5. Remove the two 6 mm T8 Torx screws from the corners of the notebook that secure the display assembly to the base enclosure.
  6. Turn the notebook right side up and open the display panel fully.
  7. Disconnect the display panel cable from its connector on the system board and remove the display panel cable from its routing channel on the top cover.
  8. Disconnect the microphone cable from its connector on the audio pass-through cable and remove the microphone cable from the routing channel on the top cover.
  9. Remove the wireless WAN antenna cables from the opening in the base enclosure.
  10. Remove the wireless WAN and wireless LAN antenna cables from their routing channel on the top cover.
  11. Remove the 4 mm P1 Phillips-head screw from the left hinge that secures the display assembly to the base enclosure.
  12. Remove the two 6 mm T8 Torx screws from the left display hinge that secure the display assembly to the base enclosure.
  13. Remove the 6 mm T8 Torx screw from the right display hinge that secures the display assembly to the base enclosure.
    Be sure to support the display assembly while removing this screw.
  14. Lift the display assembly off of the alignment pins on the top cover and remove it.
Display assembly replacement
  1. Align and place the display hinges onto the alignment pins on the top cover.
  2. Replace the 6 mm T8 Torx screw into the right display hinge that secures the display assembly to the base enclosure.
    Be sure to support the display assembly while replacing this screw.
  3. Replace the two 6 mm T8 Torx screws into the left display hinge that secure the display assembly to the base enclosure.
  4. Replace the 4 mm P1 Phillips-head screw from the left hinge that secures the display assembly to the base enclosure.
  5. Route the wireless WAN and wireless LAN antenna cables through their routing channel on the top cover.
  6. Route the microphone cable through the routing channel on the top cover and connect the microphone cable into its connector on the audio pass-through cable.
  7. Thread the wireless WAN antenna cables through the opening in the base enclosure.
  8. Route the display panel cable through its routing channel on the top cover and connect the display panel cable into its connector on the system board.
  9. Close the display panel and turn the notebook over.
  10. On the rear of the notebook, replace the two 6 mm T8 Torx screws into the corners of the notebook that secure the display assembly to the base enclosure.
  11. Replace the two rubber screw covers into the corners of the notebook.
  12. On the bottom of the notebook, replace the two 6 mm T8 Torx screws into the rear corners of the notebook that secure the display assembly to the base enclosure.
  13. Replace the 4 mm P1 Phillips-head screw in the battery bay that secures the display assembly to the base enclosure.
Parts return
