    We are upgrading our website
Compaq 515B Microtower Business PC - Specifications
Hardware specifications
Features
Chassis dimensions (H x W x D)
384 x 166 x 428 mm (15.11 x 6.54 x 16.87 in)
Temperature1
Operating: 10° to 35°C (50° to 95°F)
Non-operating: -30° to 60°C (-22° to 140°F)
Humidity1
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Altitude1
Operating: 3048 m (10,000 ft)
Non-Operating: 9000 m (30,000 ft)
System weight
10.2 kg (22.4 lb)
Power supply
300 W ATX Power supply – PFC/non-PFC with a 115v/230v line switch
Security
  • Padlock loop
  • Kensington Lock Support
  • Support for chassis padlocks and cable lock devices
1:Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Communications
Features
Communication
Wireless LAN: HP Wireless 802.11 b/g/n PCIe Card.
NICs: Intel Gigabit CT Desktop NIC.
Modem:
  • LSI PCIe x1 Hi-Speed 56K International SoftModem
  • HP RJ11 Modem Adapter Kit
Graphics
  • NVIDIA GeForce G210 HDMI PCIe x16 Card
  • ATI Radeon HD 4350 HDMI PCIe x16 Graphics Card
Audio
Features
Audio
  • Realtek ALC662 High Definition audio codec
  • 3D audio compliant and HD Audio compatible
  • HP USB Thin Powered Speakers
