HP S2032 20-inch Widescreen LCD Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked w/stand
  • 34.30 x 47.80 x 16.20 cm (13.50 x 18.82 x 6.38 in)
Unpacked w/o stand (head only)
  • 29.71 x 47.80 x 6.50 cm (11.70 x 18.82 x 2.56 in)
Packaged
  • 38.00 x 53.40 x 14.10 cm (14.96 x 21.02 x 5.55 in)
Head only
  • 2.83 kg (6.23 lb)
Unpacked
  • 3.00 kg (6.61 lb)
Packaged
  • 4.20 kg (9.25 lb)
Tilt range
5° to +20°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
ships detached
Panel specifications
Specification
Type
50.8 cm (20.0 in) Wide-Aspect active matrix TFT (thin film transistor)
50.8 cm (20.0 in) widescreen; diagonally measured
Screen opening (W x H)
44.27 x 24.91 cm (17.43 x 9.81 in)
Panel type
TN
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal/65° vertical (500:1 minimum contrast ratio)
Brightness (typical)1
200 nits (cd/m2)
Contrast ratio (typical)1
700:1
Dynamic contrast ratio (typical)1
NA
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.2768 mm
Backlight lamp life (to half brightness)
50000 hours
Color gamut
72%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches (OSD closed/OSD open)
OK/Auto, OSD down, OSD up, OSD menu select, Power
Languages
English/Spanish/French/Italian/Deutsch/Japanese/Simplified Chinese/Traditional Chinese
User controls
Picture/OSD/Display settings/Other settings/Information
Signal interface/performance specifications
Specification
Horizontal frequency
30 to 72 kHz
Vertical frequency
50 to 75 Hz
Native resolution
1600 x 900 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 640 x 480 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1600 x 900 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (5)
Anti-Glare
Yes
Anti-Static
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 ohms ± 10%
Sync Input
TTL separate synch
Video cable
One 15-pin D-sub (VGA)
Video cable lengths
1.8 m (5.9 ft)
Power specifications
Specification
Input power
100 - 240 V ac, 50 or 60 Hz
Typical power consumption
23 W
Maximum
25 W
Power saving
< 1 W
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 90%
Non-operating humidity
5% to 90%
Operating altitude
+0 to 3658 m (12000 ft)
Non-operating altitude
+0 to 12192 m (40000 ft)
