HP 620 Notebook PC - Removing and Replacing the Wireless LAN Module
This document is provided to assist in removing and replacing the wireless LAN module for the HP 620 notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Tools required
Small, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the wireless LAN module that is being replaced. If a part is listed as "Yes" under "Requires return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP
Part number
Requires return
Broadcom 4313AGN 802.11a/b/g/draft-n WiFi adapter
593836-001 (Modified)
Yes
Broadcom 4312 802.11b/g (Demi-2) WLAN adapter - Half-size form factor
504593-003 (Modified)
Yes
504593-004 (Modified)
Yes
802.11A/B/G/N WLAN Intel HMC minicard
572520-001 (Modified)
Yes
WLAN Broadcom BCM94313HMG2L Shiraz 802.11 b/g/n 1x1 half minicard
593732-001 (Modified)
Yes
Atheros 9285G 802.11 b/g/n WiFi Adapter (for use in all countries and regions
605560-005 (Modified)
Yes
Realtek RTL8191SE 802.11b/g/n WiFi adapter (for use in all countries and regions)
593533-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the wireless LAN module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Wireless LAN module from the menu on the upper left hand side of the screen.
Click here to view the wireless LAN module removal video (right-click on the link to open in a new window/tab).
Wireless LAN module removal
  2. Carefully disconnect the wireless antenna cables from the wireless LAN module by grasping the connectors with a small pair of needle nose pliers or tweezers.
    • Make careful note of which wireless antenna cable is connected to each terminal on the wireless LAN module for later replacement.
    • Use care when disconnecting the wireless antenna cables from the wireless LAN module. Damaged cables or connectors can degrade notebook performance.
  3. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN module to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN module by the edges and pull gently to remove it.
  5. Place the wireless LAN module in a static dissipative bag.
Wireless LAN module replacement
  1. Grasp the wireless LAN module by the edges and remove it from the static dissipative bag.
  2. Align the notch in the wireless LAN module with the key in the wireless LAN module slot on the system board.
  3. At an angle, gently insert the wireless LAN module into its slot on the system board.
  4. Press the wireless LAN module down and replace the two 3 mm P1 Phillips-head screws that secure the wireless LAN module to the system board.
  5. Reconnect the wireless antenna cables to the wireless LAN module.
    Use care when connecting the wireless antenna cables to the wireless LAN Module. Damaged cables or connectors can degrade notebook performance.
Country: Flag Thailand
