HP 620 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP 620 notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Tools required
Small, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part number
Requires return
500GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket - For use in models with 35.6 cm (14-inch) or 33.8 cm (13.3-inch) displays
608139-001 (Modified)
Yes
500GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket - For use in models with 39.6 cm (15.6-inch) displays
611029-001 (Modified)
Yes
320GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket - For use in models with 35.6 cm (14-inch) or 33.8 cm (13.3-inch) displays
608138-001 (Modified)
Yes
250GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket - For use in models with 35.6 cm (14-inch) or 33.8 cm (13.3-inch) displays
608137-001 (Modified)
Yes
250GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket - For use in models with 39.6 cm (15.6-inch) displays
611027-001 (Modified)
Yes
250GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm thick - Includes bracket
538972-001 (Modified)
Yes
160GB Serial-ATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
455954-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the two 3 mm P1 Phillips-head screws from the right side of the hard disk drive bracket.
  3. Loosen the captive P1 Phillips-head screw on the left side of the hard disk drive bracket.
  4. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  5. Remove the hard disk drive from the hard disk drive bay.
  6. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the hard disk drive connector.
    Ensure that the wireless antenna cables are free from being pinched between the hard disk drive and base enclosure.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two 3 mm P1 Phillips-head screws on the left side of the hard disk drive bracket.
