HP G61-424CA Notebook PC Product Specifications
Product Name
G61-424CA
Product Number
XR338UA#ABC
2.1GHz VISION Technology from AMD with AMD Athlon II Dual-Core Processor for Notebook PCs M320
Microprocessor Cache
1MB L2 Cache
Memory
4GB
Memory Max
4096MB
Video Graphics
ATI Mobility Radeon HD 4200 Graphics
Video Memory
128MB Display Cache Memory
Hard Drive
500GB (7200RPM)
Multimedia Drive
LightScribe SuperMulti 8X DVD±R/RW with Double Layer Support
15.6" Diagonal High-Definition HP BrightView Widescreen Display (1366x768)
Fax/Modem
High speed 56k modem
Network Card
Integrated 10/100 Ethernet LAN
Wireless Connectivity
  • 802.11b/g/n WLAN
Sound
  • Altec Lansing
Keyboard
101-key compatible with full-size keyboard with integrated numeric keypad
Pointing Device
Touch Pad with On/Off button and dedicated vertical scroll Up/Down pad
External Ports
  • 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
  • 3 Universal Serial Bus (USB) 2.0
  • 1 Headphone out
  • 1 microphone-in
  • 1 VGA (15-pin)
  • 1 RJ-11 (modem)
  • 1 RJ -45 (LAN)
Dimensions
14.89" (L) x 9.93" (D) x 1.38" (min H) -1.62" (max H)
5.90 lbs
Security
  • Kensington MicroSaver lock slot
  • Power-on password
  • Accepts 3rd party security lock devices
Power
  • 65W AC Adapter
  • 6-Cell Lithium-Ion Battery
What's In The Box
webcam with integrated microphone
Operating System:
Genuine Windows 7 Home Premium 64-bit
Security and Support:
Symantec Norton Internet Security 2010 60-day Trial
HP Assistant
