Compaq 420 Notebook PC - Removing and Replacing the Fan
This document is provided to assist in removing and replacing the fan for the Compaq 420 Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Fan assembly - For use in models with 15.6-inch displays
605791-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the fan, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Fan from the menu on the upper left hand side of the screen.
Click here to view the fan removal video (right-click on the link to open in a new window/tab).
Fan removal
  2. Disconnect the fan cable from its connector on the system board.
  3. Remove the 3-mm P1 Phillips-head screw that secures the fan to the system board.
  4. Lift the bottom edge of the fan and slide the fan out from in between the top cover and base enclosure.
Fan replacement
  1. Toe the fan into position between the top cover and base enclosure.
  2. Replace the 3-mm P1 Phillips-head screw that secures the fan to the system board.
  3. Connect the fan cable into its connector on the system board.
Parts return
