    Fix HP Printer issue on macOS
HP Compaq 6000 Pro All-in-One Business PC Product Specifications
Product image
Product features
Features
Processor and Speed (One of the following)
Intel Celeron Dual-Core Processors
  • Intel Celeron E3300 Processor (2.5 GHz, 2MB L2 cache, 800 MHz FSB)
Intel Pentium Dual-Core Processors
  • Intel Pentium E5400 Processor (2.70 GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E5500 Processor (2.80 GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E6600 Processor (3.06 GHz, 2MB L2 cache, 1066 MHz FSB)
  • Intel Pentium E6700 Processor (3.20 GHz, 2MB L2 cache, 1066 MHz FSB)
Intel Core 2 Duo Processors
  • Intel Core 2 Duo E7500 Processor (2.93 GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E7600 Processor (3.06 GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.0 GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16 GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8600 Processor (3.33 GHz, 6MB L2 cache, 1333 MHz FSB)
Intel's numbering is not a measurement of higher performance. Processor numbers differentiate features within each processor family, not across different processor families.
Intel Q43 express chipset
Graphics
Integrated Intel Graphics Media Accelerator 4500 HD or optional NVIDIA GeForce GT230 discrete graphics
21.5-inch diagonal widescreen full HD WLED anti-glare display (1080p)
Memory
Up to 8GB of DDR3 SDRAM supported, dual channel memory support
NIC
Integrated gigabit network connection (10/100/1000 NIC)
Optional wireless connectivity:
  • 802.11 b/g/n wireless LAN module
  • Bluetooth 2.1
Keyboard
Wired or wireless keyboard
Pointing device
Wired or wireless mouse
Storage
  • Up to 1TB hard drive, or 80GB solid state drive
Optical drive
  • Tray-load SuperMulti DVD LightScribe burner
I/O slots
Full height Mini PCIe x1
  • One (Wireless LAN module)
Half height Mini PCIe x1
  • One (TV Tuner)
Power supply
Integrated graphics
  • External 150 W power supply, 87% efficiency, active PFC
Discrete graphics
  • External 180 W power supply, 87% efficiency, active PFC
Security
  • Lock slot
  • Lockable port cover
  • Cover removal sensor
  • Integrated 1.2 TPM embedded security chip (Vista Bit-Locker ready)
  • Retaskable control buttons and audio ports
  • Optional HP ProtectTools 5.0 Security Software Suite
  • Optional HP Privacy Filter
  • USB port disable at factory
Technical specifications
Features
Interfaces
6-in-1 media card reader
Supports Secure Digital (SD, SDHC), MultiMedia Card (MMC), xD-Picture card, Memory stick, Memory stick Pro
DisplayPort 1.1
One (compatible with DP to VGA, DP to DVI, and DP to HDMI adapters) audio over DisplayPort supported with discrete graphics only
IEEE 1394 port
One
USB 2.0
Seven (2 left side, 5 rear)
Microphone jack
One
Stereo audio headphone jack
One
Stereo audio line out
One
Power connector
One
RJ-45/Ethernet
One
PS/2
Two
IR emitter (blaster) out
One (with TV tuner option only)
TV coax connector
One (with TV tuner option only); Two in Japan (with TV tuner option only)
B-CAS card reader
One (Japan only)
Audio/Visual
  • High definition audio support
  • Integrated high-performance stereo speakers
  • Volume control and mute buttons (on keyboard)
  • Integrated dual-microphone array
  • Stereo headphone jack
  • Stereo line out
Integrated HD webcam
  • Up to 30 frames/sec
  • 1280 x 720 resolution
  • Designed for low light conditions
Optional TV entertainment experience (configurable)
  • Hybrid ATSC/NTSC, Clear QAM, Over the Air TV Tuner, HW encoded
  • Hybrid PAL/DVB-T, Over the Air TV Tuner, HW encoded
  • Hybrid PAL/DMB-T, Over the Air TV Tuner, HW encoded, Hong Kong/China
  • Dual channel ISDB-T/ISDB-S, Over the Air TV Tuner, HW encoded, Japan
Infrared remote control for Media Center (with TV Tuner)
Graphics
  • Shared system memory
  • DirectX 10 capable
Discrete NVIDIA GeForce GT230 (internal MXM 3.0 connector)
  • 1GB GDDR3 800 MHz dedicated video memory
  • DirectX 10.1 capable
21.5-inch diagonal widescreen full HD WLED anti-glare display, tilt and swivel adjustments
Resolution: 1920 x 1080 resolution (16:9)
Contrast ratio: 1000:1 typical
Image brightness: 250 nits typical
Vertical viewing angle: 80° left/80° right
Horizontal viewing angle: 80° up/80° down
Memory
Standard
PC3-10600 DDR3 non-ECC SDRAM (runs at 1333 MHz)
Two 200-pin SODIMM slots supporting dual channel memory
  • 2GB (1GB x 2)
  • 2GB (2GB x 1)
  • 4GB (2GB x 2)
  • 4GB (4GB x 1)
  • 8GB (4GB x 2)
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications
Intel gigabit network connection
  • Integrated 10/100/1000 NIC
  • AMT 3.0 support
802.11 PCIe mini wireless module (optional)
  • Support for 802.11 b, g, and n
  • Up to 300 Mb/s data rate
  • Built-in dual antennas (2 transmit, 2 receive)
Bluetooth wireless technology (optional)
  • Bluetooth specification v2.1 compliant
  • Works with a wide range of bluetooth devices
Manageability
Intel standard manageability
  • ASF 2.0
  • DASH 1.0
Keyboard
Standard HP USB or PS/2 keyboard
  • 104 keys plus special keys for Mute, Volume Up, Volume Down. Separate numeric keypad. Cable length 130 cm (51 in)
Optional HP wireless keyboard
  • 104 keys plus special keys for Mute, Volume Up, Volume Down. Separate numeric keypad. Operates at ~ 2.4 GHz and supports a working distance of up to 10 m (32 ft)
Pointing device
Standard HP USB or PS/2 optical scroll mouse
Two buttons with scroll wheel acting as third button. Cable length 175 cm (69 in)
Optional HP wireless optical scroll mouse
Two buttons with scroll wheel acting as third button. Operates at ~ 2.4 GHz and supports a working distance of up to 10 m (32 ft)
Storage
Hard Drive
3.5-inch, 7200 rpm, 3.0 Gb/s, Smart IV SATA Hard Drive:
  • 250GB
  • 320GB
  • 500GB
  • 1TB
Solid state drive
2.5-inch, 3.0 Gb/s, Smart IV SATA solid state drive:
  • 80GB
Slim Optical Drive
Tray-load SuperMulti DVD LightScribe Burner
  • Read: 8x max DVD-ROM, 24x max CD-ROM
  • Write: 8x max DVD±R, 6x max DVD±R DL, 8x max DVD+RW, 6x max DVD-RW, 5x max DVD-RAM, 24x max CD-R, 24x max CD-RW
Option for no optical drive
Electrical specifications
Features
Standalone power requirements
Electrical ratings
100-240 V, 50/60 Hz, 2.0 A
Idle operating power
  • Integrated graphics: 58 W
  • Discrete graphics: 66 W
Max operating power: < 180 W
Power supply
Integrated graphics
Discrete graphics
HP Power Assistant
PC client based power management solution providing a user interface to manage the operating system power plans and power states while estimating the energy cost impact.
Physical specifications
Features
Dimensions (H x W x D)
429 mm x 546 mm x 66 mm (220 mm with stand) [16.9 in x 21.5 in x 2.6 in (8.7 in with stand)]
Packaging dimensions (H x W x D)
566 mm x 670 mm x 249 mm (21.9 in x 26.4 in x 9.8 in)
  • 8.25 kg (18.2 lb) with stand
  • 6.94 kg (15.3 lb) without stand
Shipping weight
Approx. 16.9 kg (37.3 lb)
Software/OS
Features
Preinstalled
  • Genuine Windows 7 Professional Edition 32
  • Genuine Windows 7 Professional Edition 64
  • Genuine Windows 7 Professional with Downgrade Kit for Windows XP Professional 32 bit
  • Genuine Windows Vista Business 32
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS
Supported
  • Genuine Windows Vista Business 64
  • Genuine Windows 7 Enterprise 32
  • Genuine Windows 7 Enterprise 64
Certified
SMBIOS
System Management BIOS, previously known as DMI BIOS, is used to store system management information.
Preinstalled software (varies by country)
  • HP Power Assistant
  • HP Credential Manager with Facial Recognition auto-logon
  • HP Client Automation Software Agent (preloaded)
  • HP Support Assistant
  • HP Vision Diagnostics
  • HP SkyRoom
  • HP MediaSmart applications
  • Corel WinDVD
  • Roxio Creator
  • PDF Complete
  • McAfee Total Protection
  • Microsoft Office Ready with 60-day trial
60 days trial period for McAfee Total Protection for small business software. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
Environmental specifications
Features
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-30° to 65°C (-22° to 149°F)
Relative humidity
Operating
15% to 80% @ 26°C (78.8°F)
Altitude (unpressurized)
Operating
0 to 2000 m (0 to 6,562 ft)
Non-operating
0 to 4,572 m (0 to 15,000 ft)
BFR/CFR/PVC-free
Yes, except for external power supply and power cord
Arsenic-free display
Yes
Leakage current meets NFPA99
Yes
TAA compliant
Yes
Energy consumption
100 V ac
115 V ac
230 V ac
Normal operation
38.3344 W
38.325 W
38.6587 W
Sleep (Energy Star low power mode)
4.0194 W
4.021 W
4.0931 W
Off
2.8496 W
2.8491 W
2.9215 W
Heat dissipation
100 V ac
115 V ac
230 V ac
Normal operation
131 BTU/hr
131 BTU/hr
132 BTU/hr
Sleep
14 BTU/hr
14 BTU/hr
14 BTU/hr
Off
10 BTU/hr
10 BTU/hr
10 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Declared noise emissions
System fan off
Sound power (LWAd, bels)
Sound pressure (LpAm, decibels)
Idle
3.8
27
Fixed disk (random writes)
4.1
29
In accordance with ISO 7779 and ISO 9296.
Safety certifications
Features
Eco-Label certifications & declarations
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
Industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC compliance: Yes
  • ENERGY STAR: Yes
  • EPEAT: Silver (Gold target)
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
