HP ProBook 4425s Notebook PC - Removing and Replacing the Palm Rest
This document is provided to assist in removing and replacing the palm rest for the HP ProBook 4425s Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, Phillips-head (P0 and P1) screwdrivers.
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Palm rest (includes TouchPad)
Palm rest - Includes Touchpad and fingerprint reader - For use on models with 13.3 inch displays
599549-001(Modified)
Yes
Palm rest - Includes Touchpad and fingerprint reader - For use on models with 14.0 inch displays
599550-001(Modified)
Yes
Palm rest - Includes Touchpad - For use on models with 13.3 inch displays
599551-001(Modified)
Yes
Palm rest - Includes Touchpad - For use on models with 14.0 inch displays
599552-001(Modified)
Yes
Palm rest (Red) - Includes Touchpad and fingerprint reader - For use on models with 13.3 inch displays
607648-001(Modified)
Yes
Palm rest (Red) - Includes Touchpad and fingerprint reader - For use on models with 14.0 inch displays
607649-001(Modified)
Yes
Palm rest (Red) - Includes Touchpad - For use on models with 13.3 inch displays
607650-001(Modified)
Yes
Palm rest (Red) - Includes Touchpad - For use on models with 14.0 inch displays
607651-001(Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the palm rest, click on the link below. Or use the product video listing on the HP Services Media Library, Click here to go to HP Services Media Library, then select Palm rest from the menu on the upper left hand side of the screen.
Click here to view the palm rest removal video (right-click on the link to open in a new window/tab).
Palm rest removal
  2. Partially or completely remove the keyboard. Click here for instructions on how to remove the keyboard.
  3. Temporarily, remove any card or blank from the ExpressCard slot.
  4. Remove the three 3 mm P1 Phillips-head screws that secure the palm rest to the top cover.
  5. Slide the palm rest to the right just enough to release it from the top cover.
  6. Carefully flip the palm rest upside down to gain access to the ribbon cables below.
  7. Using minimal force, lift the locking bar up on the TouchPad ZIF connector and disconnect the TouchPad ribbon cable from the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Use care to prevent damaging the ZIF connector and ribbon cable.
  9. Remove the palm rest.
Palm rest replacement
  1. Insert the fingerprint reader ribbon cable into the ZIF connector on the system board.
  2. Push the locking bar down to secure the TouchPad cable in the ZIF connector.
  3. Push the locking bar down to secure the fingerprint reader cable in the ZIF connector.
  4. Position the palm rest just to right of the screw holes in the top cover.
  5. Slide the palm rest to the left under the guide tabs in the top cover to fully seat it over the screw holes.
  6. Replace the three 3 mm P1 Phillips-head screws to secure the palm rest to the top cover.
  7. Replace any card or blank in the ExpressCard slot that you removed earlier.
Country: Flag Thailand
