HP ProBook 5320m Notebook PC - Overview
Product description
HP ProBook 5320m Notebook PC is incredibly sleek notebook which has a sophisticated aesthetic with a durable anodized aluminum display enclosure and palm rest.
Product features
Feature
Mobile Intel HM57 Express Chipset
Processors
  • Intel Core i5-450M Processor (2.40 GHz, 35 W, 3MB L3 cache, Up to 2.53 GHz with Intel Turbo Boost Technology)1
  • Intel Core i3-370M Processor (2.40 GHz, 35 W, 3MB L3 cache)1
  • Intel Core i3-350M Processor (2.26 GHz, 35 W, 3MB L3 cache)1
  • Intel Celeron Processor U3400 (1.06 GHz, 18 W ultra-low voltage, 2MB L3 cache)1
Memory
Standard: 1GB, 2GB, or 4GB DDR3 1333 MHz SDRAM SODIMM2 one SODIMM slot
Maximum: Supports up to 4GB maximum
Graphics
  • Intel HD Graphics
  • Microsoft DirectX 10 (Shader 4.0) and OpenGL 2.0 capable
Internal:
  • 13.3-inch diagonal LED-backlit HD anti-glare (1366 × 768 resolution)
  • 13.3-inch diagonal LED-backlit HD BrightView (1366 × 768 resolution)
  • HP Privacy Filter support
External:
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and lower resolutions at up to 100 Hz
  • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz with full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
Keyboard
  • The HP spill-resistant keyboard design minimizes the risk of damage to sensitive components. The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 0.19 x 0.19 m key pitch (center-to-center spacing), 0.002 m stroke, and comfort-dished keycaps.
  • HP DuraKeys is a clear coating applied over the notebook keyboard that helps protect the finish and the printed characters on the keys.
Pointing device
  • Touchpad with scroll zone, two pick buttons
  • Gestures support: two-finger scroll, zoom, pinch
Expansion card slots
Secure digital slot: Supports SD (Secure Digital), MMC (MultiMedia Card)
Storage
Internal storage device: 250/320/500GB 7200 rpm 2.5-inch SMART SATA II Hard Drive or 80/128GB 2.5-inch Solid State Drive3
HP 3D DriveGuard (Windows models only): The hard drive is mounted to the notebook frame, reducing the transmission of shock away from the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Optical drive: Optional HP External USB 2.0 CD/DVD R/RW Drive
Power supply
External 65 W Smart AC adapter, 1.8 m (6 ft) power cord included.
Total length including external AC adapter:
  • Regular: 3.66 m (12 ft)
  • Travel Adapter: 3.12 m (10.2 ft)
Battery
Primary battery:
  • 6-cell (62 Wh) high capacity Lithium-Ion
  • 4-cell (41 Wh) high capacity Lithium-Ion
Power conservation
  • Supports enhanced Intel SpeedStep technology (allows Battery Optimized Mode, Maximum Performance Mode, or Automatic mode)
  • Intel Display Power Saving technology
  • Hibernation
  • Standby
  • ACPI compliance
Communications
Integrated Realtek Ethernet (10/100/1000 NIC)4
Wireless devices
  • HP un2420 EV-DO/HSPA mobile broadband module
  • All 802.11 integrated wireless LAN options
  • Broadcom 43224AGN 802.11a/b/g/n Wi-Fi adapter
  • Broadcom 4313GN 802.11b/g/n WiFi Adapter
  • HP Integrated Module with Bluetooth 2.1+EDR Wireless Technology
Interfaces
  • External monitor: Two - DisplayPort and VGA
  • Combo stereo headphone/mic jack: One
  • Power connector: One
  • RJ-45/Ethernet: One
  • USB 2.0: Three (including one powered USB 2.0 port)
  • LED status indicators: Nine
Multimedia
  • IDT HD Audio
  • Stereo speakers
  • Integrated dual-microphone array
  • 2 Megapixel Webcam
    • Supports videoconferencing and still image capture
    • Large image sensor for excellent color matching and good low light sensitivity
    • Up to 30 frames/sec
    • Fixed focus lens
    • Video capture at VGA, 1.3 Megapixel, and 2 Megapixel resolutions
    • 16-bit true color (camera sensors output YCrCb format among others)
Security
Standard features
  • HP ProtectTools Security Manager
  • Face Recognition for HP ProtectTools
  • One-Step Logon
  • Enhanced Pre-Boot Security
  • HP SpareKey
  • HP Disk Sanitizer
  • Setup Password
  • Lock Slot
  • Support for Computrace (LoJack Pro for HP ProtectTools)
  • HP Privacy Filter (must be purchased separately)
Optional features
  • HP Fingerprint Sensor: Enhanced sensor scans the fingerprint to uniquely identify and authenticate a person.
  • HP Privacy Filter: Narrows viewing area so that screen data is visible only to persons directly in front of the monitor.
  • Computrace (LoJack Pro Premium for HP ProtectTools with GPS Tracking): Subscription based security solution providing the ability to track, initiate physical recovery, conduct asset management, and perform remote data delete by utilizing GPS technology. GPS functionality requires HP un2420 EV-DO/HSPA Mobile Broadband Module.
1: Intel's numbering is not a measurement of higher performance.
2: All memory modules operate at the maximum system supported speed of 1066 MHz, except in the case of the Intel Celeron U3400 Processor ULV processor, which limits memory speed to 800 MHz. Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. Availability of 4GB of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, memory above 3GB may not all be available due to system resource requirements.
3: Installation of a Solid State Drive on systems with Windows 7 requires system memory of 2GB or more.
4: The term "10/100/1000" or "Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Software overview
Feature
Preinstalled:
  • Genuine Windows 7 Professional Edition 321
  • Genuine Windows 7 Professional Edition 641
  • Genuine Windows 7 Home Premium Edition 321
  • Genuine Windows 7 Home Premium Edition 641
  • Genuine Windows 7 Home Basic1
  • Genuine Windows Vista Home Basic 322
  • Genuine Windows XP Professional available through downgrade rights   from Windows 7 Professional
  • SUSE Linux Enterprise Desktop 113
  • Red Flag Linux (PRC only)
  • FreeDOS
Supported:
  • Genuine Windows Vista Business2
  • Genuine Windows Vista Enterprise2
Certified: SUSE Linux Enterprise Desktop 11
Applications
Preinstalled software with Windows operating system
  • HP Recovery Manager (available with Windows 7 or Vista only)
  • HP Support Assistant (available with Windows 7 or Vista only)
  • HP ProtectTools for Central Management
  • HP QuickLaunch Buttons Software
  • HP QuickLook 3
  • HP QuickWeb
  • HP QuickSync
  • HP Power Assistant
  • HP Connection Manager 3.1
  • HP Wireless Assistant
  • HP DayStarter
  • HP Webcam Software (select models)
  • Roxio Creator 10 (select models)
  • Microsoft Office Professional 60-day Convertible Trial
  • Corel Home Office 60-day trial
  • McAfee Total Protection4
Additional software available from the web
  • HP SoftPaq Download Manager
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
