HP ProBook 6545b Notebook PC - Removing and Replacing RTC Battery
This document is provided to assist in removing and replacing the RTC battery for the HP ProBook 6545b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdrivers
Parts required
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
RTC Battery
583289-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the RTC battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select RTC battery from the menu on the upper left hand side of the screen.
Click here to view the RTC battery removal video (right-click on the link to open in a new window/tab).
RTC battery removal
  2. Disconnect the RTC battery cable from its connector on the system board.
  3. Using a non-metallic, flat bladed tool, gently pry the RTC battery out of its cradle on the top cover and remove it from the base enclosure.
RTC battery replacement
  1. Place the RTC battery into its cradle on the top cover.
  2. Press down on the RTC battery to adhere it to the top cover.
  3. Connect the RTC battery cable into its connector on the system board.
