Compaq 615 Notebook PC - Removing and Replacing Memory Boards
This document is provided to assist in removing and replacing the memory boards for the Compaq 615 Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the memory boards that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Memory 1GB SDM DDR2-PC2 6400
484380-001 (Modified)
Yes
Memory 2GB SDM DDR2-PC2 6400
484381-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory boards, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory Boards from the menu on the upper left hand side of the screen.
Click here to view the memory boards removal video (right-click on the link to open in a new window/tab).
Memory Boards removal
  2. Loosen the captive P1 Phillips-head screw that secures the memory cover to the bottom of the notebook.
  3. Lift the memory cover and remove it.
    The primary and expansion memory slots are both located under the memory cover. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory board is installed, it must be removed before the primary memory board can be removed.
  4. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the memory board by the edges and pull gently to remove it.
  6. Place the memory board in a static dissipative bag.
Memory Boards replacement
  1. Remove the memory board from the static dissipative bag.
  2. Align the notch in the memory board with the key in the board receptacle.
  3. Align the notch in the memory board with the key in the board receptacle.
  4. Press the memory board down to latch the arms.
  5. Toe the memory cover into the base enclosure.
  6. Tighten the captive P1 Phillips-head screw.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
