Compaq 610 Notebook PC - Removing and Replacing Optical Drive
This document is provided to assist in removing and replacing the optical drive for the Compaq 610 Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head (P00 and P1) screwdrivers
  • Small Torx T8 screwdriver
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
DRV ODD SATA DVD SM
538406-001 (Modified)
Yes
DVD±RW Super Multi Double-Layer combination drive with LightScribe - 12.77 mm tray load - Includes bezel and bracket
538442-001 (Modified)
Yes
DRV ODD SATA DVD-RO
575200-001 (Modified)
Yes
DVD-ROM drive - SATA interface, 12.7 mm tray load - Includes bezel and bracket - For use only on computer models equipped with an Intel processor
538441-001 (Modified)
Yes
Optical drive connector board
538460-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the optical drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Optical drive from the menu on the upper left hand side of the screen.
Click here to view the optical drive removal video (right-click on the link to open in a new window/tab).
Optical drive removal
  2. Remove the 7mm P1 Phillips-head screw that secures the optical drive to the bottom of the base enclosure.
  3. Use a small, flat-bladed tool to push out on the metal tab on the rear of the optical drive to partially eject it from the base enclosure.
  4. Grasp the optical drive bezel and pull the optical drive out of the base enclosure.
Optical drive replacement
  1. Insert the optical drive into the base enclosure until the connector is seated.
  2. Replace the 7mm T8 Torx screw that secures the optical drive to the bottom of the base enclosure.
Parts return
