    Fix HP Printer issue on macOS
HP 425/625 Notebook PC Specifications
Product image
Product features
Feature
AMD RS880M chipset
Processor (Availability depends on model, list is subject to change)
  • AMD Turion II Dual-Core Mobile Processor P520 (2.3 GHz, 2MB L2 cache)
  • AMD Athlon II Dual-Core Processor P320 (2.1 GHz, 1MB L2 cache)
  • AMD V Series Processor V120 (2.2 GHz, 512KB L2 cache)
Memory1
Standard:
  • DDR3 SDRAM (1066 MHz/1333 MHz)2
  • Two SODIMM slots supporting dual-channel memory
  • 1024MB and 2048MB SODIMMs
  • Standard memory up to 4096MB
Maximum: Upgradeable to 8192MB with optional 4096MB SODIMMs in slots 1 and 2
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
ATI Mobility Radeon HD 4200 integrated graphics controller with shared video memory Microsoft DirectX 10 capable
Display3
Internal:
HP 425 Notebook PC:
  • 14.0-inch diagonal LED-backlit HD 16:9 widescreen antiglare (1366 x 768)
  • 14.0-inch diagonal LED-backlit HD 16:9 widescreen BrightView (1366 x 768)
HP 625 Notebook PC:
  • 15.6-inch diagonal LED-backlit HD 16:9 widescreen anti-glare (1366 x 768 resolution)
  • 15.6-inch diagonal LED-backlit HD 16:9 widescreen BrightView (1366 x 768 resolution)
External: Up to 32-bit per pixel color depth
VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and lower resolutions at up to 100 Hz
HDMI 1.3 port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable (not included).
1: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires Windows Vista Business 64-bit or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
2: Maximum memory speed supported by the system is 1066 MHz.
3: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Communications
Features
Integrated Realtek RTL8153EH 10/100 NIC
  • Integrated Realtek RTL8153EH 10/100 NIC
  • V.92 56K Data/Fax Modem
  • Broadcom 4313GN 802.11b/g/n WiFi Adapter
  • Broadcom 4312G 802.11b/g WiFi Adapter
  • HP Integrated Module with Bluetooth 2.1+EDR Wireless Technology
Physical specifications
Features
Dimensions (H x W x D)
HP 425: 27 (at front) x 336 x 228 mm 1.06 (at front) x 13.23 x 8.98 in
HP 625: 27.5 (at front) x 371.8 x 249.6 mm 1.09 (at front) x 14.64 x 9.83 in
System weight1
HP 425: Starting at 2.26 kg (5.0 lb)
HP 625: Starting at 2.49 kg (5.5 lb)
Temperature
Operating: 0° to 35°C (32° to 95°F) (not writing optical)
Non-operating: 5° to 35°C (41° to 95°F) (writing optical)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
1: Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and optical drive. Weight varies by configuration and components.
Software/OS
Feature
  • Genuine Windows Vista Business
  • Genuine Windows 7 Professional Edition
  • Windows XP Professional
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
