    Apache Log4j Update
HP ProBook 6450b/6550b Notebook PC Product Specifications
Product image
Product features
Feature
  • Mobile Intel QM57 express chipset (vPro configurations)
  • Mobile Intel HM57 express chipset (non-vPro configurations)
Processor
Intel Quad-Core processor (models with discrete graphics only)
  • Intel Core i7-720QM processor (1.60 GHz, 45 W, 6MB L3 cache), up to 2.80 GHz with Intel Turbo Boost Technology
Intel Dual-Core processors
  • Intel Core i7-620M Processor (2.66 GHz, 35 W, 4MB L3 cache), up to 3.33 GHz with Intel Turbo Boost Technology
  • Intel Core i5-540M Processor (2.53 GHz, 35 W, 3MB L3 cache), up to 3.06 GHz with Intel Turbo Boost Technology
  • Intel Core i5-520M Processor (2.40 GHz, 35 W, 3MB L3 cache), up to 2.93 GHz with Intel Turbo Boost Technology
  • Intel Core i3-350M Processor (2.26 GHz, 35 W, 3MB L3 cache)
  • Intel Celeron P4500 Processor (1.80 GHz, 35 W, 2MB L3 cache)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Memory type supported
DDR3 PC3-10600 SDRAM (1333 MHz)
Memory expansion slots
Two SODIMM slots supporting dual-channel memory 1024MB, 2048MB and 4096MB SODIMMs
Maximum memory
Upgradeable to 8GB with 4GB SODIMMs in slots 1 and 2
Memory cards
  • HP 1GB (DDR3, 1333 MHz) SODIMM
  • HP 2GB (DDR3, 1333 MHz) SODIMM
  • HP 4GB (DDR3, 1333 MHz) SODIMM
Graphics
Models with discrete graphics
  • ATI Mobility Radeon HD 540v with 512MB dedicated video memory
  • Microsoft DirectX 10.1 (Shader Model 4.1) and OpenGL 2.1 capable
Models with integrated graphics
  • Intel HD Graphics
  • Microsoft DirectX 10 (Shader Model 4.0) and OpenGL 2.0 capable
Internal storage
Hard drives: 160/250/320/500GB, 7200 RPM, SMART SATA II
Solid state drive: 128/160GB
Upgrade bay
Fixed 12.7 mm SATA optical drive
  • Blu-ray ROM DVD+/-RW SuperMulti DL LightScribe drive
  • DVD+/-RW SuperMulti DL LightScribe drive
  • DVD-ROM drive
Second hard drive: 500GB 7200 RPM SMART SATA II hard drive
Internal display
HP ProBook 6450b
  • 14.0-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
  • 14.0-inch diagonal LED-backlit HD BrightView (1366 x 768 resolution)
  • 14.0-inch diagonal LED-backlit HD+ anti-glare (1600 x 900 resolution)
HP ProBook 6550b
  • 15.6-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
  • 15.6-inch diagonal LED-backlit HD+ WVA anti-glare (1600 x 900 resolution)
External display
  • Up to 32-bit per pixel color depth
  • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
  • DVI-D (single link) video signal available through DVI port in optional HP
  • Docking Station supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Communications
  • Integrated Intel 82577LM Gigabit Network Connection (vPro configurations)
  • Integrated Intel 82577LC Gigabit Network Connection (non-vPro configurations)
  • 56K V.92 modem
Wireless devices
  • HP un2420 EV-DO/HSPA mobile broadband module
  • Intel Centrino Advanced-N 6200 (2 x 2)
  • Intel Centrino Wireless-N 1000 (1 x 2)
  • Broadcom 4322AGN 802.11 a/b/g/n WiFi adapter
  • Broadcom 4313GN 802.11 b/g/n WiFi adapter
  • Broadcom 4312G 802.11 b/g WiFi adapter (Russia/Ukraine only)
  • HP Integrated Module with Bluetooth 2.1+EDR wireless technology
Multimedia
  • IDT 92HD75B High Definition CODEC
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional 2 MP webcam)
  • Touch-sensitive controls for volume up, volume down, and mute
  • Stereo headphone/line-out
  • Stereo microphone/line-in
  • Optional 2 MP webcam
    • Supports videoconferencing and still image capture
    • Large image sensor for excellent color matching and good low light sensitivity
    • Up to 30 frames/sec
    • Fixed focus lens
    • Video capture at VGA, 1.3 Mpixel, and 2 Mpixel resolutions
    • 16-bit true color (camera sensors output YCrCb format among others)
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook.
Touch-sensitive controls provide easy access to the following features: HP QuickLook 3, HP QuickWeb, wireless on/off, volume mute, volume down, volume up. The HP ProBook 6550b also features a calculator button.
Pointing device
  • Touchpad with scroll zone, two pick buttons
  • Optional pointstick with two additional pointstick buttons
Expansion card slots
  • ExpressCard/54 slot
  • Optional Integrated Smart Card Reader (replaces ExpressCard/54 slot)
  • Media card reader that supports the following:
    • Secure Digital (SD)
    • High Capacity Secure Digital (HS-SD)
    • MultiMedia Card (MMC)
    • MultiMedia Card Plus (HS-MMC)
    • Sony Memory Stick
    • Sony Memory Stick Pro
    • Memory Stick Duo
      Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
    • xD-Picture card
Security
Standard features
  • HP ProtectTools Security Manager
  • Enhanced Pre-Boot Security
  • HP SpareKey
  • One-Step Logon
  • Setup Password
  • TPM 1.2 Embedded Security Chip1
  • TPM Enhanced DriveLock1
  • HP Disk Sanitizer
  • Lock slot
  • Support for Computrace2 LoJack Pro for HP ProtectTools
Optional features
  • Smart Card Reader (replaces ExpressCard/54 slot)
  • HP Fingerprint Sensor
  • HP Privacy Filter (Narrows viewing area so that screen data is visible only to persons directly in front of the monitor)
1: TPM module disabled where use is restricted by law; for example, Russia and China.
2: The Computrace agent is shipped turned off, and must be activated by users when they purchase a subscription with terms ranging from one to five years.
Interfaces
  • ExpressCard/54 slot: One (or optional Smart Card Reader)
  • External monitor: Two - (1) DisplayPort, (1) VGA
  • 1394a: One
  • Stereo microphone-in: One
  • Stereo headphone/line-out: One
  • Power connector: One
  • RJ-11/modem: One
  • RJ-45/Ethernet: One
  • USB 2.0: One
  • eSATA/USB 2.0 combo: One
  • Serial port: One (HP ProBook 6550b only)
  • Docking connector: One
  • Secondary battery connector: One
Power supply
  • Models with discrete graphics: External 90-watt Smart AC adapter
  • Models with integrated graphics: External 65-watt Smart AC adapter
Battery
Primary battery
  • HP 9-cell (93 Wh) Li-Ion battery
  • HP 6-cell (55 Wh) Li-Ion battery
  • HP 6-cell (47 Wh) Li-Ion battery
  • HP Long Life 6-cell (51 Wh) battery (with 3-year platform warranty only)
Optional HP Long Life battery: 3-cell (47 Wh) Li-Ion battery
Optional HP Extended Life battery: 8-cell (52 Wh) Li-Ion battery
Optional HP Ultra-Capacity battery: 12-cell (95 Wh) Li-Ion battery
Electrical specifications
Feature
Nominal operating voltage
18.5 V
Max operating power
< 65 W or < 90 W
Power supply
  • Models with discrete graphics: External 90 W smart AC adapter
  • Models with integrated graphics: External 65 W smart AC adapter
Battery
  • Primary battery
  • Optional HP Long Life battery: 3-cell (47 Wh) Li-Ion battery
  • Optional HP Extended Life battery: 8-cell (52 Wh) Li-Ion battery
  • Optional HP Ultra-Capacity battery: 12-cell (95 Wh) Li-Ion battery
Technical specifications
Feature
Processor
Maximum memory
Memory cards
Graphics
  • Intel HD Graphics
Internal storage
  • Hard drives: 160/250/320/500GB, 7200 RPM, SMART SATA II
  • Solid state drive: 128/160GB
Upgrade bay
  • Fixed 12.7 mm SATA optical drive
    • DVD-ROM drive
  • Second hard drive: 500GB 7200 RPM SMART SATA II hard drive
Internal display
HP ProBook 6450b
HP ProBook 6550b
External display
Communications
  • 56K V.92 modem
Wireless devices
Multimedia
    • Fixed focus lens
Keyboard
Pointing device
    • Sony Memory Stick
    • Memory Stick Duo
    • xD-Picture card
Security
Standard features
  • HP SpareKey
  • One-Step Logon
  • Setup Password
  • HP Disk Sanitizer
  • Lock slot
Optional features
Interfaces
  • 1394a: One
  • RJ-11/modem: One
  • USB 2.0: One
Physical specifications
Feature
Dimensions (H x W x D)
  • HP ProBook 6450b: 3.38 (at front) x 33.9 x 23.62 cm (1.33 (at front) x 13.35 x 9.3 in)
  • HP ProBook 6550b: 3.48 (at front) x 37.14 x 24.8 cm (1.37 (at front) x 14.62 x 9.76 in)
HP ProBook 6450b
  • Starting at 2.26 kg (5.0 lb) with weight saver (no optical drive)
  • Starting at 2.39 kg (5.31 lb) with DVD-ROM drive
HP ProBook 6550b
  • Starting at 2.51 kg (5.5 lb) with weight saver (no optical drive)
  • Starting at 2.64 kg (5.81 lb) with DVD-ROM drive
Software/OS
Feature
Preinstalled
  • Genuine Windows 7 Professional Edition 32-bit
  • Genuine Windows 7 Professional Edition 64-bit
  • Genuine Windows 7 Home Premium Edition 32-bit
  • Genuine Windows 7 Home Premium Edition 64-bit
  • Genuine Windows 7 Home Basic Edition 32-bit (selected countries)
  • Genuine Windows Vista Business 32-bit
  • Genuine Windows Vista Home Basic 32-bit
  • Genuine Windows Vista Business available thorough downgrade rights from Genuine Windows 7 Professional 32-bit
  • Genuine Windows XP Professional available through downgrade rights from Genuine Windows 7 Professional)
  • Red Flag Linux (PRC only)
  • Free DOS
Supported
  • Genuine Windows 7 Enterprise 32-bit
  • Genuine Windows 7 Enterprise 64-bit
  • Genuine Windows 7 Ultimate 32-bit
  • Genuine Windows 7 Ultimate 64-bit
  • Genuine Windows Vista Enterprise 32-bit
  • Genuine Windows Vista Enterprise 64-bit
Certified
  • SuSE Linux Enterprise Desktop 11
Applications
Preinstalled software with Windows operating system
  • HP Recovery Manager (available with Windows 7 or Vista only)
  • HP Support Assistant (available with Windows 7 or Vista only)
  • HP ProtectTools for Central Management
  • HP Quick Launch Buttons Software
  • HP QuickLook 3
  • HP QuickWeb
  • HP Power Assistant
  • HP Connection Manager 3.1
  • HP Wireless Assistant
  • HP DayStarter
  • Microsoft Office Professional 2007 60-day convertible trial
  • McAfee Total Protection
    60-day trial period for McAfee Total Protection for Small Business software. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
  • PDF Complete SE
  • Intervideo WinDVD – DVD Player (selected models)
  • Roxio Creator Business (selected models)
  • HP Webcam Software (selected models)
  • Skype
  • WinZip v14 trial edition
Additional software available from the web
  • HP SoftPaq Download Manager
Environmental specifications
Feature
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60°C (-4° to 140°F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
  • Operating: 125 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 grms
  • Non-operating: 1.50 grms
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
Feature
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
Industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Selected models
  • EPEAT: Registered Gold in United States
  • ICES: Yes
  • GS: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KCC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
