HP Designjet 111 Printer Series - Network connection methods
The HP Jetdirect print server allows you to connect the printer to a network. See The HP Jetdirect print serverThe HP Jetdirect print server and your HP Jetdirect documentation.
There are two ways of using it to connect the printer to a network.
  • Client-server configuration. In this method the printer is connected to a computer that acts as a print server and manages the print jobs. The printer is used as a shared device.
  • Direct network setup. In this method the printer is directly connected to the network and every computer prints directly to it and manages its own print jobs. This type of connection method is equivalent to a direct connection with a parallel or USB cable. The only difference is that instead of having a direct physical link, the link is logical and it is established through the network.
