This document is provided to assist in removing and replacing the hard disk drive for the HP ProBook 4310s Notebook PC.
- ${title}
- ${title}
- ${title}
- ${title}
HP ProBook 4310s Notebook PC - Removing and Replacing the Hard Disk Drive
Minimum skill level
Tools required
P1 Phillips-head screw driver
Parts required
note:Part numbers are subject to change.
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
160GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
577198-001 (Modified)
Yes
250GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
577199-001 (Modified)
Yes
320GB SATA hard disk drive - 5,400 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
577200-001 (Modified)
Yes
500GB SATA hard disk drive - 5,400 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
577201-001 (Modified)
Yes
320GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
579212-001 (Modified)
Yes
500GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - Includes bracket and connector
579213-001 (Modified)
Yes
note:For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labelled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard Disk Drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Remove the battery. Click here for instructions on removing the battery.
Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
Lift the hard disk drive cover and remove it.
Loosen the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
Grasp the long, narrow Mylar tab to the left of the hard disk drive and pull upward to disconnect the hard disk drive from its connector on the system board.
Grasp the Mylar tab attached to the center of the hard disk drive bracket and lift the hard disk drive out of the drive bay.
Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
Remove the hard disk drive from the static dissipative bag.
Toe the hard disk drive into the drive bay and align it with the system board connector.
Press the hard disk drive into the connector on the system board until it is firmly seated.
Tighten the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
Toe the hard disk drive cover into the base enclosure.
Tighten the two captive P1 Phillips-head screws.
Replace the battery. Click here for instructions on replacing the battery.
Parts return
If your part requires return then click on the appropriate link below:
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
