HP Designjet Z5200ps Photo Printer - Printer specifications
Functional specifications
HP 70 ink supplies
Printheads
Two inks in each printhead: magenta and yellow, light magenta and light cyan, photo black and light gray, matte black and cyan
Ink cartridges
Cartridges containing 130 ml or 300 ml of ink: magenta, yellow, light magenta, light cyan, photo black, light gray, matte black, cyan
Paper sizes
Minimum
Maximum
Roll width
279 mm
1118 mm
Roll length
91.4 mm
Sheet width
210 mm (A4 Portrait)
1118 mm
Sheet length
279 mm (Letter Portrait)
1676 mm
Paper thickness
0.8 mm
Printing resolutions
Print quality
Maximum detail
Extra passes
Rendering resolution (ppi)
Printing resolution 1 (dpi)
Printing resolution 2 (dpi)
Best
On
On/Off
On/Off
On
On
Off
600 × 600
600 × 600
600 × 600
2400 × 1200 *
1200 × 1200
1200 × 600
1200 × 1200
1200 × 1200
1200 × 1200
Normal
On/Off
300 × 300
1200 × 600
1200 × 1200
Fast
On/Off
300 × 300
1200 × 600
1200 × 1200
Economode
On/Off
300 × 300
1200 × 600
1200 × 1200
The printing resolution depends on the paper type, as follows.
  • Printing resolution 1 applies to plain, coated, heavyweight coated, super heavyweight coated, satin and glossy paper.
    * Satin and glossy paper only.
  • Printing resolution 2 applies to canvas, adhesive vinyl, scrim banner, backlit, proofing matte, proofing gloss and digital fine arts paper.
Margins
Top right and left margins
5 mm
Bottom margin (trailing edge)
5 mm (roll)
17 mm (sheet)
Printing without margins is possible with glossy and satin paper types.
Mechanical accuracy
±0.2% of the specified vector length or ±0.3 mm (whichever is greater) at 23°C, 50-60% relative humidity, on E/A0 printing material in Best or Normal mode with HP Matte Film roll feed.
Graphic languages supported
HP-PCL3 GUI, CALS/G4, PostScript, PDF, TIFF, JPEG
Operating systems supported
Apple Mac OS X
10.4 and later versions
Microsoft Windows
XP and later versions
Physical specifications
Printer physical specifications
86 kg
Width
1770 mm
Depth
Minimum: 661 mm
Maximum: 732 mm
Height
1047 mm
Memory specifications
Memory (DRAM) supplied
256 MB
Hard disk
160 GB
Power specifications
Printer power specifications
Source
100–240 V ac ±10%, auto-ranging
Frequency
50–60 Hz
Current
< 2 A
Consumption
< 200 W
Ecological specifications
This product complies with European Union WEEE and RoHS Directives, and is compliant with the United States EPA's ENERGY STAR program.
For the up-to-date ecological specifications of your printer, please go to http://www.hp.com/ and search for “ecological specifications”.
Environmental specifications
Printer environmental specifications
Temperature range
Humidity range
Operating for optimal print-quality
22 to 26°C
30 to 60%
Operating for standard printing
15 to 35°C
20 to 80%
Printer without consumables
5 to 40°C
Non-operating packed consumables and printer:
-40 to 60°C
Acoustic specifications
Printer acoustic specifications (declared according to ISO 9296).
Idle sound power level
4.4 B (A)
Operating sound power level
6.5 B (A)
Idle sound pressure at bystander position
29 dB (A)
Operating sound pressure at bystander position
49 dB (A)
